Where is the place to download USB-UIRT .IR files? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-18-2012, 02:58 PM - Thread Starter
timg11's Avatar
I'm changing cable boxes and I need an .IR file to control channel changing for the SA 4250HDC. I recall there was some place where a variety of .ir files for various STBs were uploaded, but I can't find it now. They are not on the USB-UIRT web site or in the download area of the SageTV forums.
This is for SageTV 7. The existing file is located here: C:\Program Files\SageTV\Common\RemoteCodes\USB-UIRT Transceiver
The current file is SA8300hdc.ir.
The first two lines look like this:
SA8300HDC 0 0 4 400 800
0 0000 0048 0000 0018 00C0 00C1 0030 0092 0030 0092 0030 0031 0030 0092 0030 0092 0030 0092 0030 0031 0030 0031 0030 0092 0030 0092 0030 0031 0030 0031 0030 0031 0030 0092 0030 0031 0030 0031 0030 0031 0030 0092 0030 0092 0030 0030 0030 0031 0030 0092 0030 0883
I need to find SA4250HDC.ir.
Can anyone point me to the proper archive?
timg11 is offline
post #2 of 5 Old 08-19-2012, 08:20 AM
DGF
DGF's Avatar
Liked: 39
I'm not sure if this is the site you were talking about, but RemoteCentral is my go-to place for IR codes:
http://files.remotecentral.com/search/results/110457-1/index.html [This is the search results page for your SA STB box]
Failing that, actually using the USB-UIRT to capture the IR sequence from the appropriate remote is pretty straightforward.
DGF is offline
post #3 of 5 Old 08-19-2012, 12:49 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Also realize that just about any Cisco or SA codes will work. Your model uses Panasonic protocol, device 27, a code that's been around for a very long time and is used in a lot of cable boxes. I don't know anything about the USB-UIRT files, but those codes look a lot like pronto hex.
mdavej is offline
post #4 of 5 Old 08-27-2012, 05:18 PM - Thread Starter
timg11's Avatar
I didn't find any files, but I was able to create it using the USB-UIRT LRNHELPER.EXE program. Here is the SA4250HDC.ir. file contents in case anybody else needs them:
SA4250HDC 0 0 4 400 800
0 0000 0048 0000 0018 00C0 00C1 0030 0092 0030 0092 0030 0031 0030 0092 0030 0092 0030 0092 0030 0031 0030 0031 0030 0092 0030 0092 0030 0031 0030 0031 0030 0031 0030 0092 0030 0031 0030 0031 0030 0031 0030 0092 0030 0092 0030 0031 0030 0031 0030 0092 0030 0868
1 0000 0048 0000 0018 00C0 00C1 0030 0092 0030 0092 0030 0031 0030 0092 0030 0092 0030 0031 0030 0031 0030 0031 0030 0031 0030 0092 0030 0031 0030 0031 0030 0031 0030 0092 0030 0031 0030 0031 0030 0092 0030 0092 0030 0092 0030 0092 0030 0031 0030 0092 0030 0866
2 0000 0048 0000 0018 00C0 00C1 0030 0092 0030 0092 0030 0031 0030 0092 0030 0092 0030 0092 0030 0031 0030 0031 0030 0031 0030 0092 0030 0031 0030 0031 0030 0031 0030 0092 0030 0031 0030 0031 0030 0031 0030 0092 0030 0092 0030 0092 0030 0031 0030 0092 0030 0867
3 0000 0048 0000 0018 00C0 00C1 0030 0092 0030 0092 0030 0031 0030 0092 0030 0092 0030 0031 0030 0092 0030 0031 0030 0031 0030 0092 0030 0031 0030 0031 0030 0031 0030 0092 0030 0031 0030 0031 0030 0092 0030 0031 0030 0092 0030 0092 0030 0031 0030 0092 0030 0867
4 0000 0048 0000 0018 00C0 00C1 0030 0092 0030 0092 0030 0031 0030 0092 0030 0092 0030 0092 0030 0092 0030 0031 0030 0031 0030 0092 0030 0031 0030 0031 0030 0031 0030 0092 0030 0031 0030 0031 0030 0031 0030 0031 0030 0092 0030 0092 0030 0031 0030 0092 0030 0865
5 0000 0048 0000 0018 00C0 00C1 0030 0092 0030 0092 0030 0031 0030 0092 0030 0092 0030 0031 0030 0031 0030 0092 0030 0031 0030 0092 0030 0031 0030 0031 0030 0031 0030 0092 0030 0031 0030 0031 0030 0092 0030 0092 0030 0031 0030 0092 0030 0031 0030 0092 0030 0865
6 0000 0048 0000 0018 00C0 00C1 0030 0092 0030 0092 0030 0031 0030 0092 0030 0092 0030 0092 0030 0031 0030 0092 0030 0031 0030 0092 0030 0031 0030 0031 0030 0031 0030 0092 0030 0031 0030 0031 0030 0031 0030 0092 0030 0031 0030 0092 0030 0031 0030 0092 0030 0883
7 0000 0048 0000 0018 00C0 00C1 0030 0092 0030 0092 0030 0031 0030 0092 0030 0092 0030 0031 0030 0092 0030 0092 0030 0031 0030 0092 0030 0031 0030 0031 0030 0031 0030 0092 0030 0031 0030 0031 0030 0092 0030 0031 0030 0031 0030 0092 0030 0031 0030 0092 0030 0866
8 0000 0048 0000 0018 00C0 00C1 0030 0092 0030 0092 0030 0031 0030 0092 0030 0092 0030 0092 0030 0092 0030 0092 0030 0031 0030 0092 0030 0031 0030 0031 0030 0031 0030 0092 0030 0031 0030 0031 0030 0031 0030 0031 0030 0031 0030 0092 0030 0031 0030 0092 0030 0867
9 0000 0048 0000 0018 00C0 00C1 0030 0092 0030 0092 0030 0031 0030 0092 0030 0092 0030 0031 0030 0031 0030 0031 0030 0092 0030 0092 0030 0031 0030 0031 0030 0031 0030 0092 0030 0031 0030 0031 0030 0092 0030 0092 0030 0092 0030 0031 0030 0031 0030 0092 0030 0866
sel 0000 0048 0000 0018 00C0 00C1 0030 0092 0030 0092 0030 0030 0030 0092 0030 0092 0030 0030 0030 0030 0030 0092 0030 0092 0030 0030 0030 0030 0030 0030 0030 0030 0030 0092 0030 0030 0030 0030 0030 0092 0030 0092 0030 0030 0030 0030 0030 0092 0030 0092 0030 0864
timg11 is offline
post #5 of 5 Old 08-27-2012, 06:05 PM
mdavej's Avatar
Liked: 940
Your post confirms this is indeed just pronto hex from common cisco/SA codes. Here are the rest:
Code:
up 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0090 0030 0870
left 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0090 0030 0090 0030 0090 0030 0870
right 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0870
pause 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0870
guide/menu 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0090 0030 0090 0030 0870
power 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0090 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0090 0030 0090 0030 0870
info 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0870
info 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0090 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0090 0030 0090 0030 0870
down 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0090 0030 0870
select 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0090 0030 0870
video source / enter 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0090 0030 0090 0030 0870
live 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0870
ch up 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0090 0030 0870
ch down 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0090 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0870
fav 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0090 0030 0090 0030 0090 0030 0090 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0870
vol up 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0090 0030 0090 0030 0090 0030 0090 0030 0030 0030 0870
vol down 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0090 0030 0090 0030 0090 0030 0090 0030 0030 0030 0870
mute 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0030 0030 0870
list 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0090 0030 0030 0030 0870
instant replay 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0090 0030 0030 0030 0870
ffwd 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0090 0030 0090 0030 0030 0030 0090 0030 0030 0030 0870
rew 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0090 0030 0090 0030 0030 0030 0090 0030 0030 0030 0870
exit 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0090 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0870
pip ch up 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0870
a 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0090 0030 0090 0030 0090 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0870
b 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0090 0030 0090 0030 0090 0030 0030 0030 0030 0030 0870
c 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0030 0030 0030 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0090 0030 0090 0030 0090 0030 0030 0030 0030 0030 0870
play 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0870
stop 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0090 0030 0030 0030 0090 0030 0030 0030 0030 0030 0870
rec 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0030 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0090 0030 0030 0030 0030 0030 0870
pg up 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0870
pg down 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0870
settings 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0030 0030 0870
stretch mode 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0870
pip on/off 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0870
pip swap 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0090 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0090 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0870
pip move 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0870
pip ch down 0000 0048 0000 0018 00C0 00C0 0030 0090 0030 0090 0030 0030 0030 0090 0030 0090 0030 0090 0030 0090 0030 0090 0030 0090 0030 0090 0030 0090 0030 0030 0030 0030 0030 0090 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0030 0870
mdavej is offline
Reply Remote Control Area
