Can see and add devices but can't control them. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-20-2012, 07:25 AM - Thread Starter
mike mcdaniel's Avatar
Quoted: 17 Post(s)
Hello,
I have an Direct TV HR22 hooked up via cat 6, a Pioneer VSX-45 hooked up via serial. I have added the devices. I have added what i feel like is correct functions but I can't seem to get any response from any device. I have reset modem-router, switch, dvr, etc. Still no luck. Gotta be something simple. Also does anyone know which one to pick from Pioneer for the 45vsx as it's an older unit? Thanks in advance.
mike mcdaniel is offline
post #2 of 5 Old 08-20-2012, 09:31 AM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
It would be helpful if you mentioned exactly what it is that you're trying to program.
Dropkick Murphy is offline
post #3 of 5 Old 08-20-2012, 10:11 AM - Thread Starter
Quoted: 17 Post(s)
Trying to turn any of the units on, or do anything. Can't get any response from either unit. Tried changing delay and also sending info twice to the units.
post #4 of 5 Old 08-20-2012, 10:16 AM
mdavej's Avatar
Quoted: 2125 Post(s)
Liked: 940
We really need to know what hardware/software/device you are using to send the commands. Then, you need to tackle one device at a time. Have you used RS232 before, are you certain the wiring and port speeds are correct? We really need a lot more detail.
mdavej is offline
post #5 of 5 Old 08-20-2012, 03:22 PM - Thread Starter
Quoted: 17 Post(s)
Sorry i posted this in remote control area instead of in roomie remote thread. Will move it. Was wondering why i was getting questions like this.
Reply Remote Control Area
Directv , Pioneer Audio Video Reciever Vsx D457
