Harmony 900 or 1100 to be used with motorized projector screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-22-2012, 12:31 PM - Thread Starter
04rex's Avatar
Quoted: 134 Post(s)
Hey Guys, just wondering if these remotes work with motorized projector screens? There are alot of no name screen manufacturers out there. In case it does work, is it possible to set it up even if the manufacturer is not on their lit or whatever?
Also, will it control the WD HD Live media streamer?
FAMILY ROOM - Totem Tribe II LCR, JL Audio E-112, Anthem MRX 300, Apple TV Gen 3, WD HDTV, Panasonic 55" Plasma
BASEMENT THEATRE - Paradigm Studio 100 v.5 L/R, CC-690 v.5 C, Studio 10 v.5 x4 Surround Side and Backs, 4x DIY 15" Ultimax Subwoofers in 3.0 Cu Ft sealed boxes, Cerwin Vega CV-5000 for Subs, Anthem MRX 720, Outlaw Audio 7700, HTPC, Apple TV Gen 4, X-Box One, Harmony Ultimate Remote, Ben-Q W1070, 92" screen
04rex is offline
post #2 of 4 Old 08-22-2012, 12:34 PM
Ops5's Avatar
Yes. I control a Monoprice motorized projector screen with a Harmony 1100.
04rex likes this.
Ops5 is offline
post #3 of 4 Old 08-22-2012, 01:01 PM - Thread Starter
04rex's Avatar
Quoted: 134 Post(s)
Nice, did you have to set it up automatically or was it in its Manufacturer list?
04rex is offline
post #4 of 4 Old 08-23-2012, 02:38 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
So long as a device is IR it will typically be controllable by the 1100 or 900. If you get an RF controlled screen which are the most popular you will need to do a little DIY tinkering to go from IR to RF.
http://www.avsforum.com/t/1300232/ir-control-for-rf-devices
If the monoprice one's are IR then there likely in the database already.
oman321 is offline
Reply Remote Control Area
Harmony 900 Remote , Harmony 1100 Remcontrol , Projection Screens
