URC Basestation Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-19-2012, 06:38 AM - Thread Starter
M1chael's Avatar
Quoted: 12 Post(s)
Just wanted to see if someone could help me out here....I have an older URC (MX-350 Osiris) and currently have the older base station / antenna set (MRF 300 / RFX 150). I want to upgrade due to it not working all that well anymore but keep my current remote. Will the newer basestation (MRF 350 / RFX 250) work with my remote?
The URC website only mentions that the MRF 350 / RFX 250 is only compatible with MSC System Remotes which it states as MX-3000, MX-950, MX-900 and the TX-1000 remote controls. It does not say anything about the MX-350?
Does anyone know if my remote is consider an MSC Remote and compatible with the newer basestation?
Michael
M1chael is offline
post #2 of 2 Old 09-19-2012, 10:42 AM
Wendell R. Breland's Avatar
Quoted: 288 Post(s)
Liked: 157
Several years ago URC changed most of their products over to “Narrow Band FM”. I have the older MX-850 and MRF-250 base station. For the MX-850, URC tells you how to check your version by using the serial number. If you have the old version of the MX-350 then the best hope would be to find a used MRF 300 & RFX 150 or MRF-250. If yours is the new version then the new base stations should work.
Wendell R. Breland is offline
Reply Remote Control Area
