Can't get RC's (Comcast's Dark Grey) OK button (red) to function with panasonic 50v10? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-21-2012, 10:15 AM - Thread Starter
flycaster's Avatar
I have:
Panasonic 50v10
Comcast Dark Grey (with red OK button) remote.
Problem is that I can't get the right code that will allow the red OK button to function properly. Here is an example of what's happening.
I can code the RC to turn the TV on/off, and to go to the TV's menu. However, when I try to OK a selected menu item (like Picture to get the different picture modes--THX, Game, Custom, etc, for example), the Cable mode and not the TV mode lights on the RC and nothing happens.
flycaster is offline
post #2 of 5 Old 09-21-2012, 12:14 PM
mdavej's Avatar
Quoted: 2149 Post(s)
Liked: 949
Assuming you're using TV setup code 10650,
Press TV,
Hold Setup until 2 blinks
Enter 994
Tap Setup
Enter 24885
Press OK/Select
2 blinks for success
If you're using a different setup code, please change it to 10650 first.
mdavej is offline
post #3 of 5 Old 09-21-2012, 02:00 PM - Thread Starter
flycaster's Avatar
It worked! Thanks. And if I understand the process, I can now assign functionality to my RC's TV mode keys by using information from this site: http://www.getzweb.net/jp1/data_returns/DeviceEFCs.php?type=TV&devid=0650&webpid=++125
post #4 of 5 Old 09-21-2012, 02:54 PM
mdavej's Avatar
Liked: 949
Yes. But since some of those codes are ambiguous, I'll save you a little trouble. Here are all the codes you need:
Code:
0    12597
1       44341
2       45365
3       44853
4       45877
5       44085
6       45109
7       44597
8       45621
9       11573
CC      14389
CH+     52277
CH-     53301
Color Button - Blue     49973
Color Button - Green    49461
Color Button - Red      48437
Color Button - Yellow   48949
Dash- (#)       42279
Discrete Input - Component 1    15393
Discrete Input - Component 2    16417
Discrete Input - Composite 1    61749
Discrete Input - Composite 2    61237
Discrete Input - Composite 3    62261
Discrete Input - HDMI 1 54561
Discrete Input - HDMI 2 55585
Discrete Input - HDMI 3 55073
Discrete Input - PC     16181
Discrete Power Off      21045
Discrete Power On       20021
Down    25397
Exit    14119
Favorite        38439
Format  09761
Info    20789
Input   61493
Last (*)        53813
Left    24117
Menu    40757
Mute    53045
Power   20533
Return  42037
Right   25141
SAP     54069
SDHC Reader     39719
Select  24885
Self Check      18997 (warning: this will reset your tv)
Sleep   29237
Sub Menu        06695
Tuning  31797
Up      24373
VOL+    03381
VOL-    04405
Viera Cast      47911
Viera Link      55591
Viera Tools     35381
Also, the first step (Press TV) only has to be done once. And since it's a JP1 remote, you can buy or build an interface cable and simply load the codes in and drag and drop to the buttons of your choice, instead of entering one at a time by hand. You can even put functions on shifted buttons. For you could leave the menu function on the menu button and put the sub-menu function on the shifted menu button. See the manual 9xx instructions for shifted functions in the wiki link in my signature.
mdavej is offline
post #5 of 5 Old 09-21-2012, 07:04 PM - Thread Starter
flycaster's Avatar
Wow, mdavej, you've outdone yourself and have given me a lot to do if I am to customize my RC. Thanks, again...
Reply Remote Control Area
