MX-980 Downlading data to the remote impossible - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-23-2012, 07:37 AM - Thread Starter
tiger_qc's Avatar
Hi I've bought a MX-980 in 2008 and never had any problems with it for four years. I recently changed of cable supplier and have a new HD-PVR to program in the remote, so I started to program it. My problem happened when I tried to download the data in the remote a window popped;
"Connecting to MX-980 device
Loading System..."
That was okay untill another window popped;
"Not Exist RCManager.exe!"
What does it mean?
The last time I tweaked this remote was in early 2011 with my old (dead) PC. Is this a problem with my device or the editor?
I performed a live update on the editor but it still give me the same error message when I try to download the data to my remote.
I'm kind of screwed here since all my A/V devices are in a closed cabinet and I use a MRF-350 to convert the IR to RF.
I need help!
Thanks in advance.
tiger_qc is offline
post #2 of 4 Old 09-23-2012, 08:34 AM
Wendell R. Breland's Avatar
Quoted: 288 Post(s)
Liked: 157
What does it mean?
Click here to some some post at Remote Central that may help. Some more AVS post here.
Wendell R. Breland is offline
post #3 of 4 Old 09-23-2012, 04:42 PM - Thread Starter
tiger_qc's Avatar
Thank you sir your reply was really helpful I got everything working again. biggrin.gif
tiger_qc is offline
post #4 of 4 Old 03-29-2015, 06:55 AM - Thread Starter
tiger_qc's Avatar
Hello there,
Last night the screen of my mx-980 was working just fine but when I picked it up from it's dock this morning the screen was near impossible to read, it faded overnight. Everything still works it's only the screen, my lcd tv kind of did the same thing a few time when I was playing on my ps3 so I turned the ps3 and tv off, turned it back on and it was good to go. So following that logic I removed the battery and put it back in and it didn't worked, I found my original battery charged it and put it in the remote but it didn't changed a thing. Is there a way to fix this or my best bet is to get a cheap used mx-980 without software and download my data on it?
All my electronics are in a closed cabinet so I absolutely need RF, I can't go back.
Gui.
tiger_qc is offline
Reply Remote Control Area
