Xfinity remote on a Panasonic Bluray Player - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-02-2012, 07:34 PM - Thread Starter
xfinityremote's Avatar
greetings y'all,
I just wanted to see if yall can help me sync my xfinity remote to my Panasonic DMP-BD85K.
I have already got the code and perfom the basic function (power, play, pause etc) but I CANNOT seem to access the main menu of the player (viera, setup, etc) because no button the remote seems to work. The "MENU" button on the remote only pulls up the Bluraydisc menu, not the player menu. So, I was wondering if there was a way around to work it. More specifically, I need a substitute on the xfinity remote for buttons such as "Function menu" and if possible, "Viera Link" etc.
xfinityremote is offline
post #2 of 7 Old 10-02-2012, 08:24 PM
mdavej's Avatar
Quoted: 2257 Post(s)
Liked: 985
Got a picture or model number for that xfinity remote?
mdavej is online now
post #3 of 7 Old 10-02-2012, 08:33 PM - Thread Starter
yes sir: http://media2.comcast.net/anon.comcastonline2/support/remote-control/pdf/Platinum_Dark_Silver.pdf
post #4 of 7 Old 10-02-2012, 09:23 PM
mdavej's Avatar
Liked: 985
You can assign the following Advanced codes to the buttons of your choice using setup code 21362 and the manual programming instructions from the wiki link in my signature. Warning: Spoiler! (Click to show)
Code:
0    12553
1       44297
2       45321
3       44809
4       45833
5       44041
6       45065
7       44553
8       45577
9       11529
Power   20489
Open/Close      61705
Cancel* 64265
Audio   54025
Skip-   24841
Skip+   24329
Slow/Search-    60425
Slow/Search+    61449
Stop    60681
Pause   60937
Play    28425
Status  08713
Functions       41481
Top Menu        15113
Pop-Up Menu     40207
Display 46857
Sub Menu        62729
Return  63753
Up      63497
Down    62985
Left    64009
Right   29961
OK      63241
Red     57615
Green   57103
Blue    56591
Yellow  58127
Setup   46089
#       25097
PIP     40463
Secondary Audio 41487
Drive Select    35849
Viera Cast      08463
Re-Master       35081
Quick Replay    31497
Discrete ON     19977
Discrete OFF    21001
Netflix 32015
post #5 of 7 Old 10-02-2012, 10:07 PM - Thread Starter
this is just amazing. thank you so much. I've gotten the remote to be in a much better shape than it was before. I might get the JP1 cables later but for now, im glad (very)
post #6 of 7 Old 10-03-2012, 12:58 PM
mdavej's Avatar
Liked: 985
Hold the phone! I found a solution that will give you every code. I updated my original post with the new setup code and advanced codes. I added a few extra as well, like Netflix. But I'm not sure it will work on the 85. It's worth a try.
One caveat is this code will require you to assign advanced codes to most of the buttons that worked by default using code 20490, like the playback controls, numbers and power.
What you may want to do is the temporary assignment trick. That's where you temporarily assign DVD to 21362, assign the few advanced codes you need, then change back to DVD 20490. Your advanced codes should stick while unassigned buttons will use the functions from 20490. That's probably the best approach.
Let me know how they work. They should, but I could have made a mistake.
post #7 of 7 Old 10-03-2012, 04:37 PM - Thread Starter
this is great! i wil defnitely try this once im get out of work and will hit you up on the status.
Reply Remote Control Area
