I need an IR receiver for my HTPC and Harmony remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-03-2012, 04:51 PM - Thread Starter
snafu7x7's Avatar
We have a Logitech Harmony 720, our HTPC is running W7
95% of what we do with our HTPC we just use the bluetooth keyboard so we only really use the remote for volume and to switch all the components for a given function (i.e. gaming, music, tv, etc)
the problem Ive run into is that my PC won't sleep which is just needlessly burning electricity, I've tried a myriad of options to get it to snooze but none have been 100%. I would like to be able to setup my Harmony to not only shut down my components on power off (TV, receiver, etc) but also send a command to the PC telling ti to goto sleep and similarly on power on for it to revive. I assume this should be quite simple but I'll need some kind of IR receiver I can plugin to the HTPC to pick up the signal and dispatch to the PC as appropriate.
I would very much appreciate any tips or ideas, thanks guys.
S
TV: 46 in Sony Bravia XBR4
RECEIVER: Denon 4200W
FRONT: Paradigm Studio Reference 80
REAR: Paradigm ADP-150 Dipoles
CENTER: Paradigm CC-300
SUB: Paradigm PDR-12
snafu7x7 is offline
post #2 of 4 Old 10-03-2012, 07:12 PM
mdavej's Avatar
Quoted: 2128 Post(s)
Liked: 940
THIS one works great for me. Power button puts PC to sleep and any button wakes it. I use it for all media center control as well. But I get the best results if I let my PC sleep based on time only and wake it as needed. And of course I never use the included remote, just the IR dongle and my universal remote.
mdavej is offline
post #3 of 4 Old 10-03-2012, 10:24 PM - Thread Starter
snafu7x7's Avatar
thanks for the reply
so you have that working with a logitech harmony or with the original media center remote? cause I'm on XBMC and Logitech, no Windows specific stuff at all other than the OS
snafu7x7 is offline
post #4 of 4 Old 10-04-2012, 12:32 PM
mdavej's Avatar
Liked: 940
That one won't work with a media center remote, wrong IR protocol. I've used it with harmony in the past, but it works fine with any universal. I have no idea if it works with XBMC.
mdavej is offline
Reply Remote Control Area
