Harmony 890 repeating problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-07-2012, 10:50 AM - Thread Starter
AnthonyB's Avatar
I have a Mitsubishi DLP and when I put the harmony in device mode to operate the menu system to change things like contrast it will repeat the arrow keys several times.
I turned the inter-key delay up to 500Ms and that didn't help..
I also had this problem on my FiOS cable box in rf mode.. Never found a solution..
Any suggestions?
Sent from my DROID RAZR using Tapatalk
AnthonyB is offline
post #2 of 3 Old 10-08-2012, 05:59 PM
Dropkick Murphy's Avatar
Quoted: 72 Post(s)
Liked: 89
In the software go to devices tab. Click "troubleshoot" on your Mits DLP. click "remote responds too many times, or only occasionally". On the next screen decrease the setting. Save & update.
Dropkick Murphy is offline
post #3 of 3 Old 10-09-2012, 08:04 AM - Thread Starter
AnthonyB's Avatar
Thanks! I forgot about that one..
Been a harmony user for a long time, sometimes stuff like that slips your mind.
AnthonyB is offline
Reply Remote Control Area
