12v trigger for URC MX1200 based setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-11-2012, 04:21 AM - Thread Starter
akhter's Avatar
Hello:
I use an URC mx1200 remote (that I programmed myself) and my very happy with it.
I recently added a Mcintosh MC452 power amplifier to my setup but my pre-amp which is a Linn Akurate DSM does not have any triggers.
Can I buy anything that will let me send an IR signal to a 12v trigger?
akhter is offline
post #2 of 3 Old 10-11-2012, 04:09 PM
jrwhite's Avatar
This device would do the trick. You need a 12VDC source to power it, and that same 12V source could be wired to one of the relay poles to provide your 12V out.
http://www.smarthome.com/81289/Xantech-Remote-Relay-Module-1-DPDT-CC12/p.aspx
Unfortunately, unless you can find the IR codes for it ( remotecentral.com might have them ) you'll also have to buy their 'remote' so you can teach the codes to your URC.
http://www.smarthome.com/8155/Xantech-RC68-Programmer-Remote-Control/p.aspx
A little over $200 for both of them.
If you're not afraid of a little soldering, this would do the trick for $19. You would still need a 12VDC wall wart to power it, and provide the 12V to one of the relay poles to create your switchable 12V out.
http://www.electronickits.com/kit/complete/elec/ck1600.htm
Hope this helps,
Jonathan
jrwhite is offline
post #3 of 3 Old 07-15-2013, 06:37 PM
vpatel's Avatar
can you share how to program this remote? what software and where can I get a copy?
thanks
vpatel is offline
Reply Remote Control Area
Urc Universal Remote Control Mx1200 Programmable Ir Rf Remote Control
