AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Remote Control Area (http://www.avsforum.com/forum/93-remote-control-area/)
-   -   Need Marantz codes for Comcast Remote - NR1402 (http://www.avsforum.com/forum/93-remote-control-area/1435481-need-marantz-codes-comcast-remote-nr1402.html)
rtart 10-24-2012 07:32 AM
Hi folks,
I just bought a Marantz NR1402 AVR and am trying to program the Comcast remote (platinum color, 3 function) to control the volume of the AVR.
The 5-digit setup code given by the Comcast remote instructions is 30189. Obviously this does not work. I've searched the web and plugged in every 5 digit code for Marantz/Comcast that I could find. No help.
I called Marantz and was told that, first, this was not a problem - I should just buy a universal remote. Second, the issue is that Comcast does not include the codes in their remote and its not Marantz's problem. The "tech" also seemed surprised that other brands were controlled by the Comcast remote - 31 in total just in the manual.
Not exactly the answer I was hoping to receive. Other than lousy customer support, which will result in me returning their AVR to the retailer if the issue is not resolved, I am finding it difficult to believe that Comcast's remote does not support Marantz gear - especially when the remote manual list one code for it - 30189.
There is also a method to find the remote code using the remote's search feature, but this also has not resulted in success.
Any ideas?
And, as politely as I can say it, suggestions that I buy a universal remote are not helpful. I own 16 of them. I use them throughout my home to control a myriad of devices via a whole house audio system. I custom programmed three Pronto Pro remotes, so I understand the technology. This is a room that is used by my wife and kids and the Concast remote is the easiest way for them to do it.
The Marantz NR1402 is a nice little AVR, and does a nice job. However, it's going to be replaced by something else if I can't find the correct codes.
3FingeredGlove 10-24-2012 02:36 PM
Well, it obviously does work, but only for power toggle, vol+/-, the OSD, and a few of the inputs. Marantz is very friendly to us IR control freaks, and publishes the exact signals that their AVR gear responds to. The NR1402 uses the same RC5 and RC5x codes as most other Marantz AVRs. The Comcast remote can only control the RC5 signals.
If you can't get the Comcast remote to toggle power, something has gone wrong. If Vol+/- isn't working, you may need to change the Volume Punchthrough settings.
rtart 10-25-2012 07:24 AM
Well, at the risk of being argumentative, the code provided (30189) does not work. I have programmed three separate Comcast remotes with this code, two brand new from the plastic wrapper, and received the appropriate response (two blinks of the AUX light button) from each. None of the buttons, power, vol+, vol- work. I've tried all of the volume punch through settings as well.
I agree that something has gone wrong, I just can't think of any other troubleshooting steps that I have not tried.
I've seen other users on the web with similar issues with the NR1402, and none seem to have resolved their issues either.
mdavej 10-26-2012 08:40 AM
6 Attachment(s)
When you press power, vol+, vol-, which device button lights on the remote?
Try these EFCs with 30189 and see if they work. Tap setup followed by the 5 digit code below. Command is sent when the last digit is pressed and keeps sending while held.
vol up 00167
vol down 00199
power 00036
rtart 10-26-2012 11:54 AM
The AUX button lights up when I push vol+ and vol-.
I'll try the other codes.
3FingeredGlove 10-28-2012 12:41 PM
I was just reminded of a thread that display all of the Marantz IR signals that the Comcast is capable of sending. It does involve using a setup code 21781, and entering a 5 digit EFC for each signal. It's a different approach to 30189.
rtart 10-28-2012 02:32 PM
Thanks! I'm making progress!
rtart 11-01-2012 08:03 AM
vol up 00167
vol down 00199
power 00036
^^^This worked for me!! Many thanks!
Ed Montreuil 03-07-2013 05:23 PM
vol up 00167
vol down 00199
power 00036
Please elaborate on this. I'm not that tech savvy. and I don't know exactly how to do this.
chaggie 05-16-2013 11:42 AM
Does anyone know the CBL/Sat and DVD efc code for this model?
mdavej 05-16-2013 03:52 PM
6 Attachment(s)
CBL/Sat is the DSS code HERE (same thread 3FG linked in an earlier post). DVD is not possible on your remote without using a JP1 cable.
chaggie 05-16-2013 04:26 PM
thanks appreciate the help
Alex MAZ 08-24-2013 05:13 PM
Hey I just struggled through getting a friend's Comcast remote to control his Marantz NR1402 using the EFC codes discussed in this thread. Here's what I found on www.hifi-remote.com that worked for me:
Set AUX to 30189 (by pressing AUX, then SETUP until AUX flashes 2x, enter code 30189)
Then
Here's how you program an EFC on the remote...
1) Press AUX
3) Hold SETUP, 2 flashes
4) Type 994, 2 flashes
4) Tap SETUP
5) Enter the 5 digit EFC
6) Tap the button to be programmed, 2 flashes
EFC button
00167 vol up
00199 vol down
00068 mute
00036 power
Hope this works for you!
akor17 09-27-2013 05:13 PM
this worked like a charm! thank you!
SR-6008
bizwiz41 09-28-2013 07:22 AM
If the above basic commands are sufficient for your needs, then great and disreagrd the suggestions below. But, if you find you want to add other commands, (i.e. mute, sound, sleep, etc.) then you can find them by a painful process requiring some patience.
Per above "test" steps: First press "Aux" to enter the device mode for the Marantz,
Then tap "Setup"
Then start entering codes from 00000 up to 00256. You will find all the codes for your Marantz. I recommend writing down each code to ensure testing, and to log all the functions found. I've done this many times, and it really does not take that long, maybe 10-20 minutes.
mdavej 09-28-2013 11:59 AM
6 Attachment(s)
No need for that. Follow the link a few posts up for all codes.
larrypjr 02-08-2014 05:49 AM
Thank You ! Thank You ! Thank You !:)
I've been through countless Comcast service calls
and at least 5 House visits for the last 7 years to get
the Comcast remote to work with the Marantz Model SR7400 Surround Receiver.
It's great to have it all working again. Last time it worked like this was years ago with COX.
Makes the whole Comcast  viewing experience much more enjoyable with just one remote that controls
the cable box, the TV and the receiver.
Regards
larrypjr
Ed Montreuil 03-11-2014 11:24 AM
Then
1) Press AUX
4) Tap SETUP
EFC button
00167 vol up
00199 vol down
00068 mute
00036 power
This is genius, and it worked like a charm! Now...I want to do the same thing with an Onkyo TS-550 unit. What are the codes I need to do it?
mdavej 03-11-2014 12:14 PM
6 Attachment(s)
As far as I can tell, the TS-550 doesn't exist. What is the actual model number?
Ed Montreuil 03-11-2014 07:14 PM
Sorry...TX-SR500
mdavej 03-12-2014 08:43 AM
6 Attachment(s)
Originally Posted by Ed Montreuil View Post
Sorry...TX-SR500
It's a little tricky, but the procedure in this post should work for power:
http://www.avsforum.com/t/623388/remote-code-for-onkyo-a-v-receiver-tx-sr503/0_100#post_19749621
For Vol and Mute, use these codes with setup code 30135:
vol up 00183
vol down 00187
mute 00184
tedcousens 06-16-2014 03:46 PM
Then
1) Press AUX
4) Tap SETUP
EFC button
00167 vol up
00199 vol down
00068 mute
00036 power
Would this work with the cable setting as opposed to AUX?
mdavej 06-16-2014 07:41 PM
6 Attachment(s)
Yes. Just assign 30189 to CBL. Of course you'll lose complete control of your cable box. Are you sure you wouldn't rather just set volume punch thru in CBL mode?
tedcousens 06-16-2014 09:16 PM
Yes, that is what I want. Marantz volume and mute on CBL. How do I do that?
3FingeredGlove 06-16-2014 10:18 PM
1) Press Setup until 2 blinks
2) Enter 993 ( should get 2 blinks)
3) Tap AUX (AUX should blink twice)
Look here for this and other 9XX commands
tedcousens 06-16-2014 10:30 PM
No, I just want to alter volume up, volume down, and mute on the CBL channel if it is possible. Already have it on AUX but it's a pain.
3FingeredGlove 06-16-2014 11:13 PM
The 993 command sets up Volume Punch Through. The sequence I wrote above will cause button presses of Vol+, Vol-, and Mute to send IR commands for whatever is assigned to the AUX button, regardless of which device mode your remote is in. So after following the procedure I gave above, your remote will send the volume group commands to your Marantz, even if your remote is in TV or Cable mode.
tedcousens 06-17-2014 09:33 PM
Sorry, 3Fingered but I am unable to punch the 3 requested volume settings from AUX to CBL. I think I have tried all permutations of your settings - can you please give detailed explanation of how to get the three Marantz settings: vol+, vol- and mute to operate on the CBL setting? they already work on the AUX setting. It MUST be user error. Thanks.
3FingeredGlove 06-17-2014 09:50 PM
I've already given the exact sequence to follow. Let's turn this around: the remote provides feedback, so please post what it is telling you. In Cable mode, when you press Ch+, does the Cable button blink? When you press Vol+, which device button blinks?
In step 2 (enter 993) , the remote should blink once for each time you press the 9, 9, 3, and then blink twice to indicate it recognized the 993 command. Does it blink twice?
In step 3) (Tap the AUX button) the remote should blink the AUX button twice. Does it?
After completing the 3 step procedure, in Cable mode, pressing Vol+ should cause the AUX button to blink. Does it?
tedcousens 06-17-2014 10:16 PM
Thanks. Gotta sleep, will get back to you tomorrow, appreciate the help.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
