Teach a Sony RM-VLZ620 a Blu-Ray JVC XV-BP1? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-30-2012, 02:44 PM - Thread Starter
underminded999's Avatar
Quoted: 29 Post(s)
I currently have to use a minimum of two remotes to watch a BD on my JVC XV-BP1.  My AVR is pre-HDMI an Pre-BD, so no BD control there.  MY BD remote cannot control my AVR.
I have gone through a few universals and have not been pleased.
On a whim I got Sony's RM-VLZ620.  It controls all of my units with the exception of the JVC XV-BP1.  There is no JVC code and none of the BD codes, including the LG code, work.  I 'CHAT'd' with Sony support, but they were useless.
Does anyone know if I can get the Sony remote to learn the JVC's function, when no BD can be assigned?
Any help is appreciated.
underminded999 is offline
post #2 of 6 Old 10-30-2012, 03:10 PM
mdavej's Avatar
Quoted: 2125 Post(s)
Liked: 940
Of course you can. It's all HERE in the manual.
mdavej is offline
post #3 of 6 Old 10-31-2012, 10:23 AM - Thread Starter
Quoted: 29 Post(s)
I have the manual.
I tried everything before I CHAT'd with Sony.
For some reason, it will not "learn" a command, unless the BD function is 'mapped'.
It won't learn; Power, Play, Pause, Stop, etc...
I go through all of the steps, outlined on pg. 20.
Set, center button, 988, BD...
Step 5, sez, press the button , you want to learn, i.e. play, "The SET indicator flashes with the button press..."
The problem is, after pressing BD, both BD and SET are lit, then when pressing a button that I want to learn a command(Play) instead of flashing with the button press, the SET lights flashes rapidly about five or six times, then both the the SET and BD  lights turn off and I'm back to the beginning.
My assumption(you know what they say about that...) is that since the BD key is not mapped to any device/code, that it cannot learn any function for that key.
Does anyone have any suggestions on how to proceed?
post #4 of 6 Old 10-31-2012, 11:13 AM
mdavej's Avatar
Liked: 940
Just assign any valid code, doesn't matter which one
mdavej is offline
post #5 of 6 Old 11-01-2012, 12:03 PM - Thread Starter
Quoted: 29 Post(s)
I figured it out.
I found this thread over at www.remotecentral.com
It turns out that this remote can only learn with new non-rechargable batteries.
I bought some new batteries, and bingo, it has learned everything I have taught it.
Hopefully, this will help someone else, if they run into a similar problem.
post #6 of 6 Old 04-17-2013, 05:06 PM
Alan Gibs's Avatar
WOW! thanks, i just got this remote today, and was pulling my hair out! all I use and have, are rechargeable, how dumb! but, i will go get normal ones and try again, hope that works, i really was about to call and get a replacement, since i tried to get the thing to learn commands it already has, nothing, lol
Alan Gibs is offline
Reply Remote Control Area
Sony Rmvlz620 Black , Jvc Xv Bp1
