Global Cache iTach IP2IR + Command Fusion - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-10-2012, 01:18 PM - Thread Starter
Erick Guerreiro's Avatar
Hello everyone,
I am getting started to use Global Cache and I have an issue. I can learn and send ir command from iLearn using Send IR button. It works perfectly...
I think something is wrong with the router because when a send the command from Command Fusion/ iViewer the back green leds (above each port) no lighting anymore.
Do you have any idea what it can be? Maybe I forgot some important config and I can´t get this....
Thank you very much for your attention! Cheers!
Erick Guerreiro is offline
post #2 of 2 Old 11-10-2012, 03:21 PM
JarrodCF's Avatar
Make sure you are ending your commands with a carriage return as per the GlobalCache API documentation.
This is entered as \x0D in guiDesigner.
If you can provide full details on how you are connecting (post your system properties), and what messages you are sending (post the command values) then we might be able to help you.
Also, for CommandFusion support, please use our support channels:
http://www.commandfusion.com/support.html
Jarrod Bell
CommandFusion
www.commandfusion
JarrodCF is offline
Reply Remote Control Area
