Volume Turns All the Way Up When Pressed Once From The Remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-14-2012, 11:00 AM - Thread Starter
ringstadsam's Avatar
Recent issue with my Yamaha RX-V371 receiver. From the remote control, when I press the volume up button once, the volume turns all the way up by itself to the highest volume level (as if I was holding the button down). The same goes for if I am turning the volume down, it goes all the way down. Any suggestions?
ringstadsam is offline
post #2 of 9 Old 11-14-2012, 12:12 PM
mdavej's Avatar
Quoted: 2257 Post(s)
Liked: 987
If you're talking about the original yamaha remote, then change the batteries. Otherwise, post the make and model of your remote.
mdavej is online now
post #3 of 9 Old 11-14-2012, 12:20 PM - Thread Starter
Replaced batteries didn't do the trick. Problem also happens with my Comcast remote which is programmed for my receiver. The Yamaha remote I have is RAV331 / WT926700.
post #4 of 9 Old 11-14-2012, 12:54 PM
Edmund's Avatar
Quoted: 54 Post(s)
Liked: 31
Check for other remotes in the room, stuck in a cushion or under a book, sounds like IR interference, your single volume command is getting stuck in a feedback loop.
Edmund is offline
post #5 of 9 Old 11-14-2012, 12:55 PM
mdavej's Avatar
Liked: 987
If two different remotes just started doing the same thing, then something is broken in your receiver or there is a new source of IR interference in the room, perhaps a new tv, a different backlight setting or new lighting. The problem isn't the remotes, nor is there any receiver setting you can change.
post #6 of 9 Old 11-14-2012, 01:15 PM - Thread Starter
Just Christmas Lights recently - I wouldn't expect those to throw off any IR interference though. I'll problem solve tonight. Thanks
post #7 of 9 Old 11-14-2012, 01:18 PM - Thread Starter
Perhaps a Christmas Light outdoor timer about 10 feet away (has sensors in it to turn on lights once it is dark outside)! Could that be the culprit?
post #8 of 9 Old 11-14-2012, 02:39 PM
mdavej's Avatar
Liked: 987
Hmmm... don't think so. It would have to output light. A sensor shouldn't be a problem.
Try this. Get a piece of masking tape (painter's tape) and cover the IR sensor on the receiver. That cuts the amount of light without blocking it entirely, usually doing a good job of filtering out just IR noise.
post #9 of 9 Old 11-15-2012, 08:31 AM - Thread Starter
Went home last night and it worked perfectly. Very strange..... didnt change anything at all.
Reply Remote Control Area
