Can Harmony One control the Lutron Maestro MIR-LFQMT - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-02-2012, 09:54 AM - Thread Starter
JChin's Avatar
Quoted: 374 Post(s)
Liked: 210
Hi all, I want to install the Lutron Maestro MIR-LFQMT (this) to control a ceiling fan and 6 cans. Anybody done this setup before and will it work with the Harmony One?
I mean is it possible to control fan and lights as separate. Like for the fan - on/off/speed up or down and for the lights on/off/dim down or up.
JChin is online now
post #2 of 6 Old 12-03-2012, 08:34 AM
dharel's Avatar
Liked: 33
I have a regular Lutron Maestro IR dimmer and it works fine with my H1.
If the Lutron Maestro MIR-LFQMT is not in the Harmony database, you can always have the H1 learn the codes.
dharel is offline
post #3 of 6 Old 12-05-2012, 10:34 PM - Thread Starter
JChin's Avatar
Quoted: 374 Post(s)
Liked: 210
Hi dharel, thanks for the input. Can your H1 dim the lights as well?
JChin is online now
post #4 of 6 Old 12-06-2012, 04:45 AM
dharel's Avatar
Liked: 33
Yes, of course. These dimmers are IR controlled. If it's on the Maetstro remote, it can be programmed to the H1.
My dimmer is in the H1 database, so I get full functionality. I can dim up or down, go full on, full off and turn on to favorite.
As stated, if your dimmer isn't in the database, you can have the H1 learn the codes.
dharel is offline
post #5 of 6 Old 12-07-2012, 08:21 PM - Thread Starter
JChin's Avatar
Quoted: 374 Post(s)
Liked: 210
Thats great, now I need to find out if it work the same with the fan.
JChin is online now
post #6 of 6 Old 12-09-2012, 03:17 PM
dharel's Avatar
Liked: 33
I'm not sure what you're still trying to figure out here. The fan controls are IR also. Your H1 will work. As stated, anything that can be done with the Maestro remote, can be done with your H1. You may just need to learn the Maestro codes, if they aren't in the H1 database.
dharel is offline
Reply Remote Control Area
