iRule Cloud and internet access - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-04-2012, 11:27 AM - Thread Starter
dschlic1's Avatar
Quoted: 74 Post(s)
Liked: 27
I have a couple of questions concerning iRule and how it works. Once the applications are created using the oline builder and downloaded to the IOS/Android devices, will the system function without access to the internet? By this I mean that the local WiFi network is up and running, but no outside access.
The second question really concerns cloud storage in general. What happens if iRule as a company closes its doors? Do we then have no way to update/change the configuration?
LG OLED65B6P TV, Yamaha RX-V665 AV receiver, Sony BDP_S1700 Player, Klipsch F-30 speaker system
dschlic1 is offline
post #2 of 2 Old 12-04-2012, 01:30 PM
Vyrolan's Avatar
Yes and Correct, respectively.
You only need Internet access to sync your handset (meaning to pick up changes you've made in the builder). After that, it only needs your local network to access the gateways.
If iRule were to go under and turn everything off, we would probably not have a way to update the configurations unless somebody did an amazing job reverse-engineering everything which seems excessively unlikely.
Vyrolan is offline
Reply Remote Control Area
