IR / RF multi-room extender repeater suggestions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-06-2012, 06:01 PM - Thread Starter
Rockocaster's Avatar
I'd like to use a URC MX-500 in my bedroom upstairs to control a DVR in the living room downstairs.
Looked into a few products ... the NextGen will not work with the MX-500, and simple repeaters like this one I believe only give you 9 or so feet between receiver and repeater. I guess I need an extender with a transmitter and receiver.
Are there any tried-and-true extender transmitters to look at, or have any of you guys had a lot of success with any specific models?
Rockocaster is offline
post #2 of 3 Old 12-07-2012, 11:11 AM
Vin
Vin's Avatar
Quoted: 12 Post(s)
I'm a big fan of the NextGen but you're right, it won't work with the MX-500, I've tried it. I've had success with these in the past, separated by two floors, although I haven't tried them with the MX-500 > http://www.radioshack.com/product/index.jsp?productId=2049642&clickid=prod_cs
They might be worth a shot considering you could easily return them if you're not satisfied.
Vin
Vin is offline
post #3 of 3 Old 12-10-2012, 11:24 AM
tlniec's Avatar
I've used a couple of different IR repeater systems over longer extension ranges (about 20 wire feet for one that uses 3.5mm stereo cable, and about 40-50 wire feet for one that uses mono RCA cable). The stereo cable type (I think it was the Cables to Go system) is a little easier to extend, because you can just get a 20' headphone extension cable and put it right inline with the receiver eye and the box w/ the emitters. The other type (Hot Link Pro system), I ended up extending over an unused run of RG-6 coaxial cable with F-connectors on the end, so I had to get a couple of adapters (the F-RCA plug is pretty easy to find, the F-RCA jack took a bit of searching but I think Parts Express carries them).
tlniec is offline
Reply Remote Control Area
