iRule and PS3IR-1000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-10-2012, 10:07 AM - Thread Starter
ghannam's Avatar
Have all the Global Tach stuff setup and working correctly, and am looking at the Schmartz PS3IR-1000.
Do I understand correctly that I would use a 2.5 to 3.5mm adapter and a cable to directly connect the PS3IR-1000 to the GC Gateway?
If not, can someone explain how I would get the PS3IR connected for use in iRule?
Thanks a bunch for any insight.
Geoff
ghannam is offline
post #2 of 3 Old 12-10-2012, 10:53 AM - Thread Starter
ghannam's Avatar
Finally found my answer.......
ghannam is offline
post #3 of 3 Old 05-13-2013, 12:49 AM
goro007@ozemail.'s Avatar
Hi ghannam
I've got the same question. So what's the answer?!
Goro007
goro007@ozemail. is offline
Reply Remote Control Area
Irule
