Auto-Sense switch with Control Out - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-12-2012, 11:52 AM - Thread Starter
charlls's Avatar
Hey guys,
I'm looking for a simple product, that a colleague had mentioned - I can't seem to find it anywhere.
Single Display room, with HDMI and VGA at Table.
I've heard of a product that will 'auto-sense' input, and send either IR or RS-232 control to a display (for on/off).
Does this sound familiar to anyone?
If so, it'd be greatly appreciated if I could be pointed in the right direction.
Cheers,
Charles
CTS, CEDIA Designer
charlls is offline
post #2 of 2 Old 12-13-2012, 05:22 AM
ccotenj's Avatar
Liked: 101
yes, you can do this with a urc msc-400 basestation and a "power sense" dongle...
likely there are other solutions as well, that just happens to be the one that i have used... smile.gif
- chris
ccotenj is offline
Reply Remote Control Area
