MX-980 not sending RF any more!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-16-2012, 11:05 AM - Thread Starter
mpbehren54's Avatar
My MX-980 is not sending an RF signal any more. IR works fine and my other MX-980 is operating perfectly fine so I know it's not the base station. Out of warranty and sending it in seems cost prohibitive. Any ideas from anyone? Yes, I've reset the device and redownloaded the program to the device.
mpbehren54 is offline
post #2 of 3 Old 12-16-2012, 12:41 PM - Thread Starter
mpbehren54's Avatar
OK. Didn't think i could figure it out since I've never unassembled one of these before but I got it apart and solved my own problem. The RF portion of the remote is apparently the small (2x2") board that is connected at the top of the main remote board from the back. The connector is sad to say the least and the pins weren't making contact. I just added a little padding to the top and side to nudge the board over when the back was replaced. This gave the pins the contact they needed and solved my problem. I can see this being an issue for other people so I hope my solution helps others. Don't take the remote apart though unless you're OK with buying a new one!!! potential for destroying the remote this way is more than a possibility.
post #3 of 3 Old 07-29-2014, 05:43 AM
BADZ1969's Avatar
What was the steps in getting it apart without scaring the edges around? if you don't mind?
BADZ1969 is offline
Reply Remote Control Area
