URC MX Editor software update - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-31-2012, 07:00 AM - Thread Starter
jongig's Avatar
I have many MX remotes and I have the software dated 2007. I purchased a new TV and a Integra 80.3 and I was wondering if I can get the IR database update from somewhere.
I checked the URC website but they only offer the manual.
I'd appreciate the help.
jongig is offline
post #2 of 6 Old 12-31-2012, 12:16 PM
dalto's Avatar
Quoted: 1239 Post(s)
Liked: 633
The MX-Editor software is specific to the remote. Which remote are you trying to update?
dalto is offline
post #3 of 6 Old 01-03-2013, 01:43 PM
Jamie E's Avatar
URC replaced the remote-specific MX Editor software with a new software package called Complete Control Program. Unfortunately, they stopped all updates for MX Editor years ago, and left the "legacy" remotes in the dust with it. Best bet is to do the brute force method of learning each function. It's not too hard once you get in the swing of things.
Movies look their best when they look like movies. More Patton-esque remasters!
Jamie E is offline
post #4 of 6 Old 01-04-2013, 12:33 AM
dalto's Avatar
Liked: 633
Actually, not all remotes are in the CCP and the some of the MX-Editors, if you have the right versions, still provide db updates.
dalto is offline
post #5 of 6 Old 01-05-2013, 05:40 AM - Thread Starter
jongig's Avatar
Thanks for the replies. I have 4 MX-850 remotes and two MX-700 remotes. They all function the same and I have enjoyed them and the software. Since my house is using RF and many TVs are Samsung they work great by locally using only IR for the TV and then RF for other devices.
What I noticed years ago was that the codes for units like my Samsung had commands that were not on the original remote and that's why I like to get the files. I always hated using the "source" button on the remote and then I found Samsung had codes for HDMI-1 and so fourth. It made setting up macros really easy.
If I don't find updates I guess I'll work with what I have.
jongig is offline
post #6 of 6 Old 01-05-2013, 10:30 AM
dalto's Avatar
Liked: 633
The NX-RM820 editor while not totally up to date should be newer than what you have now and work fine with your remotes.
It is freely available for download if you google it.
dalto is offline
Reply Remote Control Area
