Channel Master CM7001 and Kinivo Switch IR code crossover: Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-11-2013, 06:12 PM - Thread Starter
Chris Albert's Avatar
Quoted: 29 Post(s)
Just got the components above, set it all up with a Dune player and JVC projector and guess what:
6 key on the Channel Master remote changes the Kinivo switch to input 1a
Even better the 8 on the CM remote key turns the Kinivo switch OFF.
Any solution here besides returning the Kinivo or Channel Master?
Anyone recommend a 3D capable 4x2 switch with EDID presets?
Cheers and thanks for the help.
*Quad 22L/C/12L/11L, 2x HSU VTF15H MkII subs
*4x SVS Elevation on ceiling
*Denon AVR-X4300H
*Monoprice Monolith 7x200w
* JVC RS-40 PJ
Chris Albert is offline
post #2 of 2 Old 01-21-2013, 07:55 AM - Thread Starter
Quoted: 29 Post(s)
No one's seen this before? Why would a manufacturer use IR codes that another device already uses?
*Denon AVR-X4300H
* JVC RS-40 PJ
Reply Remote Control Area
