Yamaha 4300 Sound Bar discrete power codes? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-13-2013, 10:15 AM - Thread Starter
htsource's Avatar
I picked up a Yamaha 4300 sound bar, hoping it would have discrete ON/OFF IR codes. I can hook it with RS232 control, but I don't know the pinout since the back of the bar has a RJ45 end. I was hoping the codes for their receivers would work but I tried the CCF codes and not responding.
I have an ELAN system that I'd really need to integrate this into, much appreciate your assistance.
htsource is offline
post #2 of 2 Old 01-13-2013, 10:59 AM
3FingeredGlove's Avatar
Quoted: 22 Post(s)
Liked: 39
Most Yamaha Sound bars or Sound Projectors use the NEC1 IR protocol device 120. Receivers use 122 or 126. Try these:
Power On: Device 120, function 126
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
Power Off: Device 120, function 127
0000 006C 0022 0002 015B 00AD 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 05F7 015B 0057 0016 0E6C
IR codes from http://www.awe-europe.com/ir_232.html using YSP4100-IR. Conversion to Pronto Hex using IrMaster.
3FingeredGlove is offline
Reply Remote Control Area
Ysp 4300 Digital Sound Projector With Wireless Subwoofer
