Free ios/android app to test global cache device? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-13-2013, 02:20 PM - Thread Starter
wallace4793's Avatar
Hi
I'm looking for a free app to test the gc100 I have bought. I imagine looking at irule as a longer term option but would like a free app to play with first.
John
wallace4793 is offline
post #2 of 4 Old 01-13-2013, 04:22 PM
Steve Goff's Avatar
Quoted: 341 Post(s)
Liked: 161
I don't know of a free app to test your iTach but you can use Fing to make sure that you've correctly connected it to you network.
Steve Goff
Steve Goff is offline
post #3 of 4 Old 01-14-2013, 09:14 AM
DGF
DGF's Avatar
Liked: 39
IIRC doesn't iRule (and maybe DemoPad) offer free trials? You could kill two birds with one stone!
You've probably seen this, but if it's just basic connectivity testing you want to do, Global Cache has a crude windows-based app (iHelp) that will confirm everything is hooked up correctly and talking:
http://www.globalcache.com/downloads/
DGF is offline
post #4 of 4 Old 01-14-2013, 10:15 AM
jautor's Avatar
Quoted: 1331 Post(s)
Liked: 852
Yeah, use iHelp... You don't want another app in the chain of things until you know that you've got the backend working. If you're using IR codes (as opposed to RS232 or contact closures), I'd highly recommend using an emitter with a visible LED, or one of the Xantech "Test IR" (just an LED that acts like an emitter), so you know that you're getting "something" at the outputs.
I struggled for a while when you don't know if 1) the GC received the command, 2) the output configuration is correct, or 3) the IR codes are correct... Having a visible LED on the emitter at least tells you that #1 and #2 are working, so the problem is #3. biggrin.gif
Jeff
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is offline
Reply Remote Control Area
Irule
