Marantz and Musical Fidelity have same remote codes, help please? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-15-2013, 02:30 PM - Thread Starter
Regnad's Avatar
I just bought a Musical Fidelity preamp and its volume and mute remote signals are the same as the Marantz AV7005 Surround Processor.
Imagine the fun!
Just looking for any advice on how to fix this.
Regnad is offline
post #2 of 3 Old 08-26-2015, 02:17 PM
Liked: 0
Hi,
I'm in similar territory. Did you find a solution?
philandsue is offline
post #3 of 3 Old 08-27-2015, 06:27 AM
dalto's Avatar
Quoted: 1242 Post(s)
Liked: 634
If neither has the capabilities of changing the IR code set then you need to find a control solution that support IR routing.
dalto is online now
Reply Remote Control Area
