Dual/Triple IR emitters? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-22-2013, 08:44 AM - Thread Starter
purbeast's Avatar
Quoted: 14 Post(s)
Liked: 27
I'm just wondering if anyone has any specific brand emitters they like and haven't had any issues with. I plan on ordering my stuff from Amazon today and would like to find some on there if possible, that people have had success with. From reading the reviews it seems that some of them don't stick very well on the IR panels of the devices, so that is one area I'm wondering about as well.
I plan on purchasing this later - http://www.amazon.com/gp/product/B0064OFSOO/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A33RI86K4PO1EO
And right now I'm also looking at the Logitech PS3 IR adapter.
And then these emitters have caught my eye, but they do not have any reviews so I figured I'd just ask here before I purchase them.
http://www.amazon.com/Head-Emitter-Cable-Blaster-Plus/dp/B008NMJQ3Y/ref=sr_1_11?s=electronics&ie=UTF8&qid=1358872673&sr=1-11&keywords=ir+emitter
So anyone have any from Amazon that they recommend, that come via prime?
purbeast is offline
post #2 of 2 Old 01-22-2013, 09:37 AM
bryansj's Avatar
Quoted: 1196 Post(s)
Liked: 586
Don't worry if they don't stick very well. Just break out the hot glue gun and they won't be going anywhere. You could also tape over them to hold them in place. If you use non-transparent tape you can also prevent IR bleed from other IR signals, but that usually isn't an issue unless you are running multiples of the same device.
bryansj is online now
Reply Remote Control Area
