Logitech Harmony software won't remember logins. Fix? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-27-2013, 12:14 PM - Thread Starter
Babaganoosh's Avatar
All of a sudden the Logitech Harmony software won't remember my login information. I always check the box that says 'remember' but the software won't do it. Any idea on how this can be fixed?
"I bought a new camera. It's very advanced. You don't even need it."
- Steven Wright
Babaganoosh is offline
post #2 of 4 Old 01-27-2013, 01:51 PM
jjk454ss's Avatar
I noticed mine doesn't either, it used to but that was on a different computer, since installing it on my new Mac Mini it won't remember it,
jjk454ss is offline
post #3 of 4 Old 01-27-2013, 02:02 PM - Thread Starter
Over on the Logitech forums they're telling me that this was intentionally disabled! I wonder why Logitech did that. It's making it very hard to use a secure password, since cut-and-paste doesn't work... frown.gif
- Steven Wright
post #4 of 4 Old 01-28-2013, 07:33 AM
BPlayer's Avatar
This change was made in early January, not sure why.
I use LastPass for my secure passwords. LastPass will automatically log into the member.harmony just fine when I need to do a simple check. For more involved changes I use the software and cut and paste of the password works fiine.
BPlayer is offline
Reply Remote Control Area
