Software to identify received commands by Zotac AD-10 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-28-2013, 09:20 AM - Thread Starter
marcosreg's Avatar
Does anybody knows a software to be installed in a Zotac mini-pc to show me the commands received from it's IR remote control?
I need to know what is sent when I press the power on and power off keys on the AD-10 Zotac mini-pc.
I know the GC-IRL IR Learner from Global Cache, but it costs 85 bucks, too much to learn just two codes.
Any help?
Thank you
Marcos
marcosreg is offline
post #2 of 4 Old 01-28-2013, 09:32 AM
mdavej's Avatar
Quoted: 2213 Post(s)
Liked: 969
THIS solution is only about $30. I have one, and it works beautifully.
marcosreg likes this.
mdavej is online now
post #3 of 4 Old 01-28-2013, 12:35 PM
DGF
DGF's Avatar
Liked: 39
FWIW, I did see some Zotac-related discussions on a Linux blog and someone posted what look like IR hex strings for discrete commands that might be relevant to what you're trying to achieve:
http://ben.periton.co.uk/2012/06/configuring-the-zotac-zbox-remote-control/
...and there are quite a few (maybe) related discussions from Zotac-users using XBMC that might give you some pointers.
Looks like a very interesting box - I need to check it out further!
Dave
DGF is offline
post #4 of 4 Old 01-28-2013, 03:48 PM - Thread Starter
marcosreg's Avatar
Zotac AD-10 comes with an USB IR receiver.
Do you think I can use it with the IR_Scope?
Marcos
Reply Remote Control Area
