Sony VPL-VW60 RS232 Codes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-29-2013, 06:56 PM - Thread Starter
coffeeguy57's Avatar
I just wanted to contribute...It may be a little late since this PJ is a little old (only a couple years for me) but none the less Im doing a remote revamp and I made a spreadsheet of all the SET codes for the VW60.
WARNING!!! this is a Macro enabled Spreadsheet their is a VBA module to calculate the checksum. Just incase you want to use them as GET commands or change them based on PJ model. Just wanted to let you know!biggrin.gif Looks like they will work with some other Sony PJs as well. VPLVW60RS232.zip 87k .zip file
coffeeguy57 is offline
post #2 of 3 Old 01-31-2013, 06:37 PM - Thread Starter
UPDATED...My first file was flawed...my checksum was wrong. The file has been updated and it works!
post #3 of 3 Old 06-08-2016, 06:59 PM
Liked: 0
hi can i check with you do you have sony vpl-fhz65 rs232 code? i having a problem looking for the codes please help!
thanks.
Ji Xiang is offline
Reply Remote Control Area
Sony Vpl Vw60 Home Cinema Projector
