URC RF20 question - AVS Forum | Home Theater Discussions And Reviews
Old 01-29-2013, 09:24 PM - Thread Starter
wbender's Avatar
I have easily set up and programmed my RF20. Only problem so far is how to get the channel selector to change via the cable box and the volume to control the Onkyo receiver without having to change devices. I can't seem to program the toggle switches via a macro. Any suggestions? Thanks.
wbender is offline
Old 01-29-2013, 10:52 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
Go into the menu of the RF20 , select Punch Through, chose volume, pick the device the volume is coming from, then the device you wish to punch the volume to.
Edmund is offline
Urc Mastercontrol Rf20 Universal Learning Remote W Rf Capability
