Inexpensive Sony (or other) suggestion ? - AVS Forum | Home Theater Discussions And Reviews
Old 01-31-2013, 10:20 AM - Thread Starter
calvinb's Avatar
Just looking for a few suggestions: Am looking for a remote that would control an older Sony Soundbar (CT-150), a newer Sony Blu-Ray player and a DirecTV STB. If it could power on a Sanyo projector that would be a grand slam. That part is not important.
Not looking to spend a lot of $$. Doesn't have to be a Sony but that would seem to make sense. Not looking for RF functionality. Anyone have any knowledge of this remote?: http://www.amazon.com/Sony-RMVLZ620-Universal-Remote-Control/dp/B00385XUG0/ref=sr_1_1?s=electronics&ie=UTF8&qid=1359652536&sr=1-1&keywords=sony+remote+control
Bottom line: just looking for an easy solution for my kids. The entertainment area is a garage 90% of the time and tailgate area during football season. Any help is much appreciated.
calvinb is offline
Old 01-31-2013, 10:34 AM
jautor's Avatar
Quoted: 1221 Post(s)
Liked: 782
My cheap go-to remote is the $20 WR7 from URC. Cheapest learning remote and has power macro capability and volume punch-through...
http://www.amazon.com/URC-Universal-Control-Components-Favorite/dp/B001KC08A4/ref=sr_1_1?ie=UTF8&qid=1359653671&sr=8-1&keywords=wr7
Jeff
jautor is online now
Old 01-31-2013, 11:07 AM - Thread Starter
calvinb's Avatar
Much thanks jautor! One final question: do I dare ask if this thing would work with a PS3? I suspect the answer is "No" due to the Bluetooth issue. Occasionally the PS3 gets pulled out to the garage for gaming. Thanks again.
calvinb is offline
Old 01-31-2013, 11:54 AM
mdavej's Avatar
Quoted: 2132 Post(s)
Liked: 942
Yes it will. Any universal will work with a PS3 if you buy an IR adapter for it. They range from about $8 (Nyko bluwave at wal-mart) to $150 or so. The adapter often comes with it's own remote, but you're only interested in the adapter. Just put the remote away.
mdavej is online now
