No remote on/ off - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-02-2013, 08:24 AM - Thread Starter
Den85's Avatar
I bought a hdbaset 4x4 matrix and it came with a small remote to change inputs. But it seems kinda odd that it doesn't have an on/ off button. There is a rocker switch on the front of the unit. 95% of the time the unit will stay on but I would like to turn it off the odd time as it gets fairly warm. I plan on getting the harmony one soon to see if that might work. If not, is there something that would work? Thanks
Den85 is offline
post #2 of 5 Old 02-02-2013, 10:27 AM
jautor's Avatar
Quoted: 1299 Post(s)
Liked: 832
Those devices are intended to be left on all the time. I put all of my distribution equipment on a set of power strips that I can turn off when I'm going to be out of town (to save the power, heat, and in case of a storm), but other than that, it stays on
jautor is offline
post #3 of 5 Old 02-02-2013, 10:30 AM
mdavej's Avatar
Quoted: 2212 Post(s)
Liked: 969
It's highly unlikely anything can override that toggle switch.
mdavej is offline
post #4 of 5 Old 02-03-2013, 01:01 PM
DGF
DGF's Avatar
Liked: 39
There are IR and IP-controllable power strips, if you want to go that route.
DGF is offline
post #5 of 5 Old 02-03-2013, 02:32 PM - Thread Starter
Den85's Avatar
Thanks for the replies. I'm not sure what I will do. Leaving it on is the easiest since it defaults to input one when its turned back on. My main reason to turn it off is to fix some minor issues it has. The odd time the image will start to flicker; then flicker green after a while and then go out if left long enough. Restarting it always fixes it ( which causes me to go to the basement and turn it off) I guess that is another thread. Thanks for the responses.
Den85 is offline
Reply Remote Control Area
