URC Mx780 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-03-2013, 06:26 PM - Thread Starter
mhaneef's Avatar
Does the URC Mx780 suffer from the same "re-learning" bug as the consumer R40? Does it recognize device states? Lastly, would it control my Lutron lighting ( Spacer system plus odd Maestro) and Mitsubishi mini-split? Thanks for the advice- can't find these specifics.
mhaneef is offline
post #2 of 3 Old 02-05-2013, 08:10 AM
adk highlander's Avatar
The MX-780 is a pro remote and is configured using CCP (Complete Control Program). I am not aware of any re-learing issues with the 780 and have been using one for well over 6 months.
You can use variables to keep track of the state of a device. If possible and your gear has discrete codes for power this may not be necessary. You have to configure all of your activities with the CCP software. All macro's are created by hand in the software by the user.
Is your Lutron IR or RF? If it is IR then yes no issues. If it is RF then only if it is Lutron's URC specific products.
adk highlander is offline
post #3 of 3 Old 02-05-2013, 03:35 PM - Thread Starter
mhaneef's Avatar
Thanks for the input, much appreciated.
mhaneef is offline
Reply Remote Control Area
Mx 780 Universal Remote Control
