Harmony 650 remote doesn't change Input on my Sound Bar - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-06-2013, 11:47 PM - Thread Starter
Dave Bohnen's Avatar
When I change an activity the input on my sound bar does not change. The Device turns on and the TV changes to the correct input but the sound bar input has to be changed by going into devices and doing it through there.
How can I fix this?
Dave Bohnen is offline
post #2 of 4 Old 02-07-2013, 10:58 AM
bryansj's Avatar
Quoted: 1123 Post(s)
Liked: 555
Make sure the soundbar device is included in the activity and then manually add the input command to the activity.
bryansj is offline
post #3 of 4 Old 02-07-2013, 03:58 PM - Thread Starter
I did set it up that way. It adjusts when I hit the "help" button and it asks if the sound bar is on the correct input I hi NO until it sets on the right input.
Did I configure something incorrectly?
post #4 of 4 Old 02-11-2013, 09:12 AM
mychaelp's Avatar
You may need to set up a delay for the device. When I set mine up and the TV didn't change inputs properly I did it through the web interface. I could only select a 2 second delay though. Some devices when they turn on, they take a few seconds before you can set the input. That is probably the problem. One other possible issue is the input button didn't program automatically and may need to be "learned". If that doesn't work. I suggest adding a second input button on the remote, either a button or on the LCD, then when everything is on, just push it to get it to the right input. I have to do that with my projector because it takes 10 seconds to come on, much longer than the delay that can be set.
By the way, I'm starting to begin writing simple product reviews of A/V equipment I buy and own on my new site with remote control information http://thecreativealternative.com/logitech-harmony-650-remote/
I hope to get input from people as I progress with it and other products. When I was searching for information before buying the 650 I couldn't find a site easily with the information I needed so I decided to create one myself.
mychaelp is offline
Reply Remote Control Area
Logitech Harmony 650 Remote Control Silver
