Looking for a URC MX-450 Remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-07-2013, 06:46 AM - Thread Starter
nem
nem's Avatar
I have the MX-650 and the MRF-260 base station. The RF module in the 650 decided it no longer wanted to work. I could shake the remote and here something was loose inside. URC states the whole remote needs replacing and there is no fix for the RF module. Im looking into the MX-450 for a replacement. Looking a a reputable place to purchase this remote . Locally they want to bend me over on the pricing.
nem is offline
post #2 of 9 Old 02-07-2013, 11:36 AM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
Try taking mx-650 apart and resitting the RF circuitry. To take it apart, start at the bottom of the remote, with little force to separate the halves slightly just enough to get a corner of a credit card in, then slide it around popping the catches.
Edmund is online now
post #3 of 9 Old 02-07-2013, 04:05 PM - Thread Starter
nem
nem's Avatar
I took it apart no problems with that. The RF chip was loose. Where does it sit and what contacts to mate together?
nem is offline
post #4 of 9 Old 02-07-2013, 05:19 PM - Thread Starter
nem
nem's Avatar
Here is what I have. What goes where? LOL!!! I am thinking the i have it the right way and have tried moving the module on different points with no luck
nem is offline
post #5 of 9 Old 02-07-2013, 06:56 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
Mine looks like this:
On yours it needs to be resoldered just below where it says CON3 on the circuit board.
post #6 of 9 Old 02-08-2013, 06:47 AM - Thread Starter
nem
nem's Avatar
thanks, Ill try that tonight. crossing my fingers!!
nem is offline
post #7 of 9 Old 02-09-2013, 07:53 AM - Thread Starter
nem
nem's Avatar
tried and was unsuccessful. It did send a signal in RF as I saw the emitters flash. I guess Ill suck it up and but a new 450. Thanks so much for the help though.
nem is offline
post #8 of 9 Old 02-09-2013, 09:06 AM
JJ7
JJ7's Avatar
Quoted: 37 Post(s)
Just curious– how many years did you get out of your remote before it gave up the ghost?
JJ7 is offline
post #9 of 9 Old 02-09-2013, 05:50 PM
hdtvluvr's Avatar
Quoted: 33 Post(s)
Liked: 31
Why the 450? The mx-850 is still available and the layout is exactly the same as the 650. Also, the 850 is programmed with a PC.
hdtvluvr is offline
Reply Remote Control Area
Universal Remote Control Mx 450 Custom Programmable Remote Control With On Screen Macro Editing , Universal Remote Mrf 260
