Networked RCA Switch - AVS Forum | Home Theater Discussions And Reviews
Old 03-04-2013, 03:15 PM - Thread Starter
WakeUpWolfgang's Avatar
I have a situation where I need to be able to switch in between many different RCA connections to one TV. It is in an out of reach location where having one with buttons or a turn knob will not work. I cant use an auto one because the signal is always going to the TV with the different connections. So instead of using a ladder to change it I am looking for a networked one so I can change it from any computer on the network. Is there such a device out there? I spent hours on Google and now I am here.
WakeUpWolfgang is offline
Old 03-04-2013, 04:21 PM
alk3997's Avatar
Liked: 93
Many ones with RS-232 connections. That's still the normal way for system integrators. Also is possible to use USB.
If you are looking for RJ-45 Ethernet, then I haven't seen any.
http://www.neoprointegrator.com/avalon.php
alk3997 is offline
Old 03-04-2013, 04:23 PM
DGF
DGF's Avatar
Liked: 39
Try searching using "audio video switcher remote" as your keywords (or maybe insert "composite" instead of "audio video") - there are lots of different options, depending on how much you want to spend.
Edit: Sorry - just re-read your post and saw you're looking for a networked version - definitely a rarer beast!
DGF is offline
Old 03-04-2013, 11:16 PM
jautor's Avatar
Quoted: 1221 Post(s)
Liked: 782
How about the least expensive AVR with network support (and therefore, an "app" these days)? Onkyo and others have published the API, so easily controlled with a computer, too (with a little programming).
jautor is offline
Old 03-05-2013, 07:18 AM - Thread Starter
I will ask if thy want to go with the avr. I work for a security company and we have a lot of AVRs here. I wanted to avoid that to try to keep the price down but if it is that rare I doubt it will be cheap if it dose exist.
Thanks for the advice.
