Sony STR-D665 IR Code - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-09-2013, 11:53 AM - Thread Starter
joeycannoli's Avatar
Trying to program a Sony STR-D665 receiver (i know i know, its old but it is the in-laws) with a universal remote, but cant get it working. Does anyone know the three digit IR code for this receiver? I searched high and low on the internet but have not been successful in locating it. Any help would be appreciated
joeycannoli is offline
post #2 of 10 Old 03-09-2013, 12:13 PM
Vin
Vin's Avatar
Quoted: 12 Post(s)
Like most Sony receivers, yours is probably factory set to AV2 and universal remotes need AV1 in order to work. If you can't find the procedure for switching it in the manual (assuming you have the manual) you can find the procedure for your particular receiver here: http://www.remotecentral.com/cgi-bin/mboard/rc-sony/thread.cgi?4020
Vin
Vin is offline
post #3 of 10 Old 03-09-2013, 12:38 PM - Thread Starter
Thanks Vin. Not finding it in the manual and of course the reciever is not on that list... Any other ideas?
post #4 of 10 Old 03-09-2013, 02:20 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
You're going to have to tell us what universal remote you have. They all use different codes.
mdavej is offline
post #5 of 10 Old 03-09-2013, 02:57 PM
Vin
Vin's Avatar
Quoted: 12 Post(s)
Do you happen to know if his receiver is factory set to AV2 and if so won't it need to be changed to AV1?
Vin
Vin is offline
post #6 of 10 Old 03-09-2013, 03:04 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
The str-d665 comes set to av1 codeset, no need to switch from av2, if it even can.
http://www.remotecentral.com/cgi-bin/mboard/rc-sony/thread.cgi?keywords=5889&highlight=str-d665
Edmund is online now
post #7 of 10 Old 03-09-2013, 03:09 PM
Vin
Vin's Avatar
Quoted: 12 Post(s)
Okay, so then I guess it's just a matter of identifying the right code for his particular remote as mdavej alluded to.
Vin
Vin is offline
post #8 of 10 Old 03-09-2013, 03:33 PM - Thread Starter
Its from Service Electric - UR5U-9020L (Phazr-5 Cable Remote Control). Thanks so much for the help guys
http://www.universalremote.com/products/cable/digital-remotes/ur5-9000l-series
post #9 of 10 Old 03-09-2013, 04:10 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
test all keys, with stereo on, from these codes:
001, 018, 247, 248, 166, 101, 184, 218, 271, 560, 612.
The volume keys may not work initially because of a punch through from cable or tv device.
post #10 of 10 Old 03-09-2013, 05:33 PM - Thread Starter
Reply Remote Control Area
