Looking for remote for HK AVR 247 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-19-2013, 11:04 AM - Thread Starter
weez82's Avatar
Hello. Hopefully Im posting in the correct forums. Not sure if here or the Receiver forums. But anyways, I need a new remote for my HK AVR 247. Will this one work? http://www.amazon.com/gp/product/B007ZT0W2U/ref=s9_simh_gw_p23_d0_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-3&pf_rd_r=1SD0SWDBP3D0CVXMG06W&pf_rd_t=101&pf_rd_p=470938811&pf_rd_i=507846 If not is there a remote for under $25 that will? I did see some used AVR 247 remotes on ebay but it looks like shipping would take almost a month, looking to avoid that if possible. I also found this http://www.amazon.com/gp/product/B009D5Q28W/ref=s9_simh_gw_p23_d0_i4?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=0G1WX1XR1T2MN1RGSK7D&pf_rd_t=101&pf_rd_p=1389517282&pf_rd_i=507846 but would like to stay under $25. But if there is a remote for under $50 that I can use with the 247 and windows 7, I would be open to that
weez82 is offline
post #2 of 2 Old 03-19-2013, 05:31 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
First link sure looks the same as this:
http://www.newremotecontrol.com/Mfrs/OtherBrands/Def/dyn_part_data.php?catnum=CARTAVR247 I'd go with $22 HK on amazon.
Edmund is offline
Reply Remote Control Area
Harman Kardon Avr 247 Home Theater Receiver W Hdmi Connectivity
