Help needed for Pioneer Elite receiver remote to control Panasonic Plasma TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-19-2013, 01:42 PM - Thread Starter
garytjia's Avatar
I bought a Pioneer Elite receiver VSX-53 and tried setting up the remote to control Panasonic HDTV TH58PXU60. I used the discrete codes provided in the Pioneer manual for Panasonic TVs, but could not get any of them to work.
Has anyone with the same components able to setup the Pioneer remote to control the Panasonic TV? Any help or advise is greatly appreciated.
garytjia is offline
post #2 of 3 Old 03-19-2013, 04:10 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Discrete codes? I assume you mean setup codes. I'm very surprised none of the panasonic tv codes worked. But the Pio remote is learning, so just learn what you need from the tv remote. First I would try those codes again. Perhaps you made a mistake.
mdavej is online now
post #3 of 3 Old 03-19-2013, 04:23 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
Perhaps someone already taught commands, was it used? try resetting remote, and then retry the panasonic tv codes
Edmund is offline
Reply Remote Control Area
Pioneer Elite Vsx 53 Av Network Receiver 7 1 Channel 3d , Panasonic Th 58px60u 58 Inch Plasma Hdtv
