CCP software for MX-880 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-01-2013, 07:45 PM - Thread Starter
foxnews's Avatar
I just bought URC MX-880 from ebay but it does not come with software. How do I get the CCP software for this remote? thanks.
foxnews is offline
post #2 of 3 Old 04-01-2013, 08:34 PM
alk3997's Avatar
Liked: 92
http://www.avsforum.com/t/1278954/urc-programming-software-for-mx-980
(It was the fifth post when searching the AVSForum for "CCP Software")
alk3997 is offline
post #3 of 3 Old 04-02-2013, 05:49 AM
bryansj's Avatar
Quoted: 1123 Post(s)
Liked: 555
Most URC MX remotes on eBay don't come with the software. When buying a URC MX remote on eBay you need to already have the software or have a source lined up for obtaining the software.
You should probably try to return it to the seller, or ask at Remote Central (http://www.remotecentral.com/cgi-bin/mboard/complete/thread.cgi?4821) where they are often very helpful.
bryansj is offline
Reply Remote Control Area
Urc Mx 880 48 Device Ir Rf Remote With Color Lcd
