are my Harmony 700 batteys worn out? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-02-2013, 06:06 PM - Thread Starter
stevethebrain's Avatar
Quoted: 104 Post(s)
Liked: 25
are my Harmony 700 batterys worn out?
my Harmony 700 is about 1 1/2 year old since I've had it.
I charge the batterys pretty much everyday.
Usalley when I initalley plug in the AC power the remote displays it's charging now it dos'nt display the charging status it just stays on activitys today is the second day it's done this.
The remote works fine just concerned if it's actualley charging?
Thanks STB
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
post #2 of 7 Old 04-04-2013, 09:13 AM - Thread Starter
Quoted: 104 Post(s)
Liked: 25
Dave or Bryan are you there? I'm in need of assistance.
this is day three I have no battery charging display.
Should I be checking into two double AA litium batteries? or can I use my Ray O Vac hybrid rechargables. I don't want a explosion.
STB
post #3 of 7 Old 04-05-2013, 07:00 AM
bizwiz41's Avatar
Quoted: 14 Post(s)
STB
It does sound like your batteries may be going. However, replace with NiMH batteries (AA R6).
Sometimes I have to remind myself that I bought all this "stuff" to enjoy it!
bizwiz41 is offline
post #4 of 7 Old 04-05-2013, 08:19 AM - Thread Starter
Quoted: 104 Post(s)
Liked: 25
OK Thanks where do you think I can obtain these batteries?
I sure hope the Harmony isn't ruined could'nt image going back to a device type remote.
these look exactly like the batteries that came w/ the remote.
http://www.amazon.com/Sanyo-Eneloop-Pre-Charged-Rechargeable-Batteries/dp/B000IV2WAW
this appears to be the better deal
https://www.all-battery.com/cart.aspx
STB
post #5 of 7 Old 04-05-2013, 01:11 PM
bizwiz41's Avatar
Quoted: 14 Post(s)
STB
The attached link would not take me to the battery model, but as long as they're NiMH (Nickel Metal Hybrid) and rechargeable, they should be fine.
The "Sanyo Eneloop" batteries are good, but EXPENSIVE! I have a set, but there are better deals out there. You mentioned the Ray-O-Vac NiMH, those should work as well. Sorry I didn't mention that in my earlier post.
bizwiz41 is offline
post #6 of 7 Old 04-06-2013, 06:24 AM - Thread Starter
Quoted: 104 Post(s)
Liked: 25
I have these Rayo Vacs only two I use in my seldom used digital camera, did'nt relize they where in fact
NiMH (Nickel Metal Hybrid) so I'll try them in the Harmony.
I'm thinking the Harmonys slow charge won't create an explosion because these Rayo Vacs did come w/ there own charger which is also a very slow charge usalley 8+ hours.
I'm curious if these NiMH (Nickel Metal Hybrid) are smart like cell phone batteries and have a memerey of what is a full charge? Nowadays I condition all rechargables like run then down to compeletly dead then recharge just in case they do have a memerey.
since these NiMH (Nickel Metal Hybrid) lifespan is calculated by # of charges I think I'll reduce the # of times I recharge from everyday to every other day.
I'm now on the lookout for a deal on some NiMH (Nickel Metal Hybrid).
Thanks STB
http://www.amazon.com/gp/product/B001KYFZ6Y/ref=cm_cr_asin_lnk
post #7 of 7 Old 04-06-2013, 06:35 AM
bizwiz41's Avatar
Quoted: 14 Post(s)
Thanks STB
A decent set of NiMH batteries should last 1 1/2 - 2 years no problem; that would be charging every day as well. If you current batteries are in that age range, then they are likely ready for replacement. My point is don't worry too much about having to monitor the batteries, as to charging, etc. I would just "set them and forget them" for the next year or so.
bizwiz41 is offline
Reply Remote Control Area
New Harmony 700 Universal Remote Tv Home Video
