Code for Comcast remote to control Sony Blu-Ray receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-12-2013, 10:18 AM - Thread Starter
Caps18's Avatar
I am trying to get a Comcast remote with a red OK button to control a Sony BDV-T58 Blu-Ray/Receiver combo. I really only need it to control the power on/off and the volume buttons though. I have tried all the codes from Comcast's website, and tried the 991 code search, but nothing has worked so far. The Sony remote that came with it is RM-ADP057.
Does anyone else have this device? The Comcast manual says it should be a 4 digit number, but all of the ones I have found have been 5 digits.
Any insight into what I should try?
HD-DVD:34
Blu-Ray:0
Caps18 is offline
post #2 of 3 Old 04-12-2013, 12:03 PM
3FingeredGlove's Avatar
Quoted: 22 Post(s)
Liked: 39
See this thread at RemoteCentral. It tells how to manually program your Comcast remote to control units like the Sony combo. Get the 994 EFC instructions from this newer link.
Very new Comcast remotes and the Atlas 1056B03 have a setup code 32522 which will work without modification, but most Comcast remotes don't have this setup code.
3FingeredGlove is offline
post #3 of 3 Old 04-14-2013, 10:55 PM - Thread Starter
Caps18's Avatar
Thanks for that advice. I did have to manually program each button, but it does work for the power and volume now.
HD-DVD:34
Blu-Ray:0
Caps18 is offline
Reply Remote Control Area
