Harmony Ultimate, Smart Control and Hub - Page 101 - AVS Forum | Home Theater Discussions And Reviews
 59Likes
post #3001 of 3005 Old Yesterday, 02:02 PM
bweissman's Avatar
Quoted: 116 Post(s)
Liked: 52
Originally Posted by LRS3 View Post
They are Logitech Harmony Precision IR Cables, and I bought them directly from Logitech. They cost about $25, and the box has 2 cables with 4 emitters per cable.
How long are these cables, please? The Logitech page doesn't say.
bweissman is offline
post #3002 of 3005 Old Yesterday, 07:20 PM
kgveteran's Avatar
Quoted: 155 Post(s)
Liked: 81
I replaced a Harmony 1100 with the Ultimate Home and was successful in transferring my old activities to the new unit.
With regard to the emitters, I think they are compatible, but there is a limitation. On my old Harmony 1100, the hub had outputs for 4 emitter cables. On the Ultimate Home hub, there are only 2 outputs for emitter cables. On the old 1100 hub, each cable had 2 emitters, while the optional cables (these have to be purchased separately; they are not included with the Ultimate Home) for the Ultimate Home hub have 4 emitters per cable. So, each hub could support 8 emitters, but the newer model accomplishes this with 2 cables instead of 4.
To keep your existing emitters, it depends on how many components you have and where they are located in your rack. I thought I could re-use my existing emitter cables, but ultimately I had to replace them with the new version. Like I said, the new version has to be purchased separately. They are Logitech Harmony Precision IR Cables, and I bought them directly from Logitech. They cost about $25, and the box has 2 cables with 4 emitters per cable. Photo attached.
Thank you, its rare to get a complete answer from a first hand user, Thank You very much !
kgveteran is offline
post #3003 of 3005 Old Today, 05:39 AM
mecmec's Avatar
Quoted: 139 Post(s)
Liked: 53
The wires of the Precision IR Cables are 8 feet in total length. The split in the cable comes 3 feet up giving you 5 feet for each wire.
mecmec is offline
post #3004 of 3005 Old Today, 05:42 AM
mecmec's Avatar
Quoted: 139 Post(s)
Liked: 53
anyone needing anything from harmony. go to this link and fill out the "work hard" or "play hard" questionnaire. It is good for a unique $20 code for $49 or more.
http://www.bts2015.logitech.com/en-u...ign=BTS2015_US
mecmec is offline
post #3005 of 3005 Unread Today, 12:23 PM
hearrean's Avatar
Quoted: 30 Post(s)
Question Upgrading TV Models?
Forgive the lame question, but can someone tell me the best way to change my TV model in the computer set-up? Would it be "rename this device" or do I have to delete it & re-add? I replaced my Samsung TV with a new model. I will say this though; so far I've found that pretty much all Samsung TV models will work on the Harmony w/o updating the models. But I thought this time, I'd make sure all of my devices would match what the on-line set-up shows.
The optimist claims the glass is half full; the pessimist claims it is half empty. An engineer observes that the glass is twice as big as it needs to be.
hearrean is online now
Reply Remote Control Area
Logitech 915 000201 Harmony Ultimate Remote , Logitech 915 000194 Harmony Smart Control
