Harmony Ultimate, Smart Control and Hub - Page 118 - AVS Forum | Home Theater Discussions And Reviews
 107Likes
post #3511 of 3540 Old 11-27-2016, 07:04 PM
JerryIII's Avatar
Quoted: 40 Post(s)
Liked: 36
Has anyone had an issue with signing into harmony software to update? It keeps asking me to create a new account? I am running an Elite.
Samsung PN51D550 | Sony PS3 | Sony PS4 | Apple Ariport Express | FIOS TV and Internet | Emotiva UMC-200 | Parasound HCA2003 | Parasound HCA1500a x 2 | Samson S1000 | Berhinger BFD | Monster HTS3500 | NHT 1.5 | NHT VS2 | NHT Super Ones | SVS PC Ultra x2 | Harmony Elite | Salamander Venice 237 | Sound Anchors Cone Coasters
JerryIII is offline
post #3512 of 3540 Old 11-27-2016, 07:58 PM
Kai Winters's Avatar
Not here.
Earlier in the week every time I started the program, Windows 10 laptop, it asked for my PW then said it was incorrect so I clicked on "forgot pw...etc" and it would accept my PW and log in.
Several days later, I was doing a lot of tweaking as it is a new Harmony remote, it started as normal logging me in right away and is still working well.
I wonder if it is the Harmony server?
Good luck and keep us informed.
TV: Samsung 60KS8000, Rcvr: Pioneer Elite VSX-21TXH, Speakers: front/Paradigm Monitor 11v5, center/Paradigm CC-290, surround/Paradigm Atom, sub/Paradigm PDR-12, DVD: Samsung BD-J5700, Remote: Logitech Harmony Ultimate Home
Kai Winters is offline
post #3513 of 3540 Old 11-29-2016, 09:51 AM
jeff1967's Avatar
Quoted: 24 Post(s)
Liked: 356
Software update?
I just updated my harmony app on my iPad. When I launched it I got this message:
Support for version 3.12x will end in March of 2017. We recommend you update the software......
I am assuming they are referring to the software in the Hub?
Anyone else get this message that can clarify?
Panasonic TC-P55ST50 Plasma 55"
Oppo BDP-83 Blu Ray, Toshiba A30 HD DVD
Onkyo RZ-900 Receiver (7.1 Config)
Klipsch R28F, RC500, RS400, RB600, SW10 Sub
Cisco Explorer 8642HDC HD DVR
Mac Mini/PS3/Wii, Harmony Smart Control
jeff1967 is offline
post #3514 of 3540 Old 11-29-2016, 09:41 PM
sbalasu3s's Avatar
Quoted: 22 Post(s)
I posted this question in the logitech forum. Thought i would post it here as well (let me know if there is a different section in this forum for this question that can be better answered).
I am having trouble controlling the 2 denon receivers when using in Multi zone setup. I have a Main Denon X6200W in my basement which also houses my other entertainment devices. Using Zone 2 HDMI of this device, i am sending the pass-thru HDMI signal to my living room Denon Receiver (3808CI) using HDBASET (with bidirectional IR).
Except my Watch TV activity all are Zone 2 based. My Watch TV activity is a bit different. I have my Verizon cable box in the living room and its connected directly to the living room Denon Receiver 3808CI. Now, my issue is when i use harmony to 'Watch TV' activity, i expect only the Living room denon to turn on+the Verion Setop Box and the TV. But, what happens is my basement Denon 6200W also turns on. I guess its due to the same IR command used by both as they are same brand. I dont want this to happen.
How do i stop the Basement Denon from turning on?. Is there a way to add the Denon basement receiver via Wifi/IP based instead of IR in the harmony?. Please note that the way i talk via harmony to the Basement Denon receiver is thru a IR In dongle connected to the HDBASET Receiving Unit in the living room. There is a Transmitting HDBASET unit in the basement which has a IR Out dongle pointing at the basement Denon Receiver.
sbalasu3s is offline
post #3515 of 3540 Old 11-30-2016, 06:32 AM
rehaz1's Avatar
Quoted: 52 Post(s)
Liked: 30
I believe that Denon AVRs support multible IR Command sets, check your owners manual to find out how this can be changed on one of your AVRs, then change the command set used by your Harmony for that AVR
rehaz1 is offline
post #3516 of 3540 Old 11-30-2016, 07:55 AM
sbalasu3s's Avatar
Quoted: 22 Post(s)
Well, my Denon 3808CI has Device Versions and i tried setting it up, but stil no use as the power on command is transmitted to the basement receiver also.
But, someone in Logitech forum was able to help. He told to assign a specific blaster to the Basement Receiver. So i did that and isolated that Blaster and HDBASET IR dongle in a corner - so the hub doesn't leak t the dongle. Now that makes it work and my Basement Receiver doesn't turn on when I 'Watch TV'.
Another question:
Is there a way in Harmony to tell if the basement Receiver Main Zone is not active/on, then turn off the receiver completely?. As such with Zone 2 setup, it leaves the Zone 2 On. I can understand why it does (becos to avoid turning the main Zone off if the main zone is in use by someone else).
post #3517 of 3540 Old 11-30-2016, 12:45 PM
Sgooter's Avatar
Quoted: 96 Post(s)
Liked: 81
I embarrassed to admit it, but I may have the blue-stripe battery operating my brain because I can't remember this little detail about the Harmony programming software:
Can the Harmony One be programmed using the My Harmony software?
Can the Ultimate One be programmed using the Logitech Harmony software that was packaged with the Harmony One remote?
Please enter password to view this signature.
Sgooter is online now
post #3518 of 3540 Old 11-30-2016, 12:57 PM
Audio Geek's Avatar
Quoted: 87 Post(s)
Liked: 41
https://support.myharmony.com/en-us/...h-amazon-alexa
I just discovered that Alexa (e.g. Amazon Echo) can connect directly to Harmony now (was using SmartThings). One advantage is that it's easier to add a number of aliases. Apparently, this feature had been available since October.
Audio Geek is offline
post #3519 of 3540 Old 11-30-2016, 01:29 PM
sbalasu3s's Avatar
Quoted: 22 Post(s)
Yes..I did the other day. Not sure about the Ultimate One - i guess it should.
post #3520 of 3540 Old 11-30-2016, 02:21 PM
mdavej's Avatar
Quoted: 2068 Post(s)
Liked: 927
You should program both with the latest My Harmony software from the Logitech website, not with whatever came in the package with your possibly 9 year old remote. If it's old enough to have come with the 7.7 or earlier software, the Ultimate One won't work with it anyway.
mdavej is online now
post #3521 of 3540 Old 11-30-2016, 03:31 PM
Sgooter's Avatar
Quoted: 96 Post(s)
Liked: 81
Thanks folks - much appreciated. You're right - my H1 software is v7.7.
post #3522 of 3540 Old 11-30-2016, 04:38 PM
jong1's Avatar
Quoted: 107 Post(s)
Liked: 86
I've a Harmony 900 (much like the "One" but with the four colour buttons) and an Ultimate.
Obviously, I use My Harmony software with the Ultimate.
The 900 still has to use the ancient Logitech Harmony Software (V7.7). Fortunately, it still works perfectly on Windows 10. Although I think the Harmony One can use either, if I had set everything up already using LHS 7.7 I think I would probably stick with it.
jong1 is online now
post #3523 of 3540 Old 11-30-2016, 06:43 PM
I'm using Harmony's latest software and it...the server...had my Harmony 1 info on it, from the older software, and I added my Harmony Ultimate Home remote to it as well.
In my opinion, based on over 10 years of Harmony remotes, the latest software is great and the HUH remote is also a great remote...easy to program and tweak activities, etc.
post #3524 of 3540 Old 12-01-2016, 01:20 AM
Strider-'s Avatar
Is there a way to get this out of the box with the Harmony? I kicked one of my AVRs over to remote code 2, and managed to do a real ugly hack to load the commands onto a remote... But if there is an out of the box way to do this for the Harmony, that would be awsome.
Strider- is offline
post #3525 of 3540 Old 12-01-2016, 03:08 AM
Brian Hampton's Avatar
Quoted: 553 Post(s)
Liked: 282
Hello,
I used Harmony remotes before and then spent a long time with only the iphone as a remote using Roomie.
Now, I have the Smart Control kit and I really, really, like the handheld remote it comes with.
However,.... I can't imagine how to program control of the lights with it.
So far I have some activities but what I'm looking for is what buttons to use for various light controls. Looking at the remote I don't see anything particular that suggests lighting controls.
Actually... Looking at the remote I guess I will start with the color buttons (Red, Green, Yellow, Blue) ... I guess Red will be intermission lights, Blue will be Lights off, Green will be lights up and I'll figure a "scene" for yellow.
Edit - That didn't work because it doens't see my lights as a device I can assign buttons to. ??
-Brian
Brian Hampton is online now
post #3526 of 3540 Old 12-01-2016, 07:30 AM
rehaz1's Avatar
Quoted: 52 Post(s)
Liked: 30
To answer your second question the answer is no, it can only be programmed using the MyHarmony software, The Harmon y One can be programmed using either software
rehaz1 is offline
post #3527 of 3540 Old 12-01-2016, 09:02 AM
mdavej's Avatar
Liked: 927
Originally Posted by jong1 View Post
... I think the Harmony One can use either, if I had set everything up already using LHS 7.7 I think I would probably stick with it.
It can. But MyHarmony has some advantages over 7.7 like much longer sequences and generally better UI.
post #3528 of 3540 Old 12-01-2016, 09:04 AM
jong1's Avatar
Quoted: 107 Post(s)
Liked: 86
Yeah, no doubt My Harmony is better. As I said, I use it on my Ultimate.
I guess my needs are relatively simple in my kitchen and I can see no reason to ever want to move everything over from the old app. But that won't be true for all, I agree.
jong1 is online now
post #3529 of 3540 Old 12-06-2016, 04:12 AM
Vipfreak's Avatar
Quoted: 75 Post(s)
Liked: 75
I've had the 900 remote for a long time and I recently got the Harmony Hub (no remotes, hub only) and installed the app. I'm assuming you can't rearrange the touch controls in the app... ? I absolutely hate flipping screens to get to more buttons...
My Summer Motto: "When Nature turns off the damn heat I'll turn off my A/C"
Vipfreak is offline
post #3530 of 3540 Old 12-06-2016, 10:04 AM
maestreaux's Avatar
Quoted: 82 Post(s)
Wondering same thing here. Just got the Hub and set it up last night. using the app to control my cable box is very frustrating. Different buttons on different pages. No button for DVR, or Live. Is there anyway to rearrange or reprogram them? Same with the physical remote. Anyway to reprogram them? Missing a few essential buttons.
maestreaux is offline
post #3531 of 3540 Old 12-06-2016, 11:42 AM
gregoryperkins's Avatar
Quoted: 399 Post(s)
Liked: 143
You get a lot more buttons on a tablet, at least on IOS.
gregoryperkins is online now
post #3532 of 3540 Old 12-06-2016, 01:19 PM
Wondering what I did wrong?
Hi,
When I synch my Ultimate Home remote it now wants me to do it from the settings on the remote rather than via the "synch" tab on the Harmony app on my laptop.
The only thing I did was when adding a new background to the remote I clicked on "clear cache" tab on the laptop app and when I clicked on the synch tab rather than getting the usual synching screen I got a screen to use the settings/synch on the remote itself.
Is this something I did?
It works fine and is not a problem but I'd like to know if it was something I did and how the heck I did it...should not have played around with it after an overnight shift and very tired hehehe.
Thanks for any help you offer.
Problem Solved:
I made a few other tweaks to the remote, activities, and when synching it, the typical synch screen showed on my laptop. I guess the other method was for background changes/add, etc.
post #3533 of 3540 Old 12-06-2016, 01:24 PM
Vipfreak's Avatar
Quoted: 75 Post(s)
Liked: 75
No difference on android...
Vipfreak is offline
post #3534 of 3540 Old 12-07-2016, 07:03 AM
rallen's Avatar
I notice that with the APP, I get a lot more buttons on my Nexus 10 than my Android smart phone. I got a cheap 7" tablet just for the app and I get more than the phone, but less than the Nexus 10.
I was hoping I could scroll through, but it doesn't seem to allow that. Seems like something you should be able to do.
rallen is online now
post #3535 of 3540 Old 12-07-2016, 09:23 AM
maestreaux's Avatar
Quoted: 82 Post(s)
I installed the app on my old S3 phone and then on my 10" galaxy tab. Very big difference. The app on the tablet is so much better. All the commands on one page. Able to edit, move them around and reorder them.
post #3536 of 3540 Old 12-07-2016, 01:21 PM
Hi I'm trying to create a remote “activity” (play music) that will switch to the USB drive that is connected to the Samsung One Connect Mini box.
The current activity starts the devices and the TV goes to the Smart Hub display. I then click on the “Firebird USB” device icon to open the USB drive accessing the song list. It works fine but can I fine tune the activity so it goes directly to the Firebird USB drive when I start the activity.
I haven’t figured out how to do it and ask for your suggestions.
There is no input on the Harmony activity page for the USB specifically.
Current Activity for “play music” via USB drive connected to Samsung One Connect Mini box.
Remote’s Activity Setup: Samsung TV is used to “play music” via Smart Hub input and uses the HDMI 1 STB to show the song list on the screen. The receiver is used to control volume, etc. via DVR input and using an optical cable from the receivers DVR optical input to Samsung One Connect Mini box optical output. USB drive is connected to the “5V .5A” port on the One Connect Mini box.
Remote: Harmony Ultimate Home
Devices: Samsung UN60KS8000FXZA and Pioneer Elite VSX-21THX
post #3537 of 3540 Old Yesterday, 10:16 AM
Liked: 0
Hi all,
With the Smart Hub Remote, How do I assign the music button, movie button and the TV button to an activity? When I try and assign it I cant get the options to use the 3 main shortcuts at the top of the remote.
Name:	HnruWI2 - Imgur.png
Technisearch is offline
post #3538 of 3540 Old Yesterday, 08:03 PM
rehaz1's Avatar
Quoted: 52 Post(s)
Liked: 30
Originally Posted by Technisearch View Post
Hi all,
You can't those are Activity buttons to start an activity, and can't be added to another activity
rehaz1 is offline
post #3539 of 3540 Old Yesterday, 09:57 PM
Liked: 0
But I only have 3 Activities in total
1 for Xbox (which I wanted to be the Music button)
1 for Cable (which I wanted to be the TV button)
and 1 for Plex (which I wanted to be the Movie button)
post #3540 of 3540 Old Today, 07:43 AM
Quoted: 399 Post(s)
Liked: 143
How are you trying to do it? I didn't have a problem setting them up. You're using the app, correct?
Reply Remote Control Area
Logitech 915 000201 Harmony Ultimate Remote , Logitech 915 000194 Harmony Smart Control
