Harmony Ultimate, Smart Control and Hub - Page 126 - AVS Forum | Home Theater Discussions And Reviews
 128Likes
post #3751 of 3762 Old 05-03-2017, 04:30 PM
scrapser's Avatar
Does the Ultimate have a limit on the channel numbers? I posted a thread for this question but also adding it here. I seem to only get channels up to 999 but my cable provider has numbers up to 1699. The MyHarmony app on Logitech's website only shows up to 999 channels from my cable service and hence, so does the remote after setup. This really seems odd to me in this day and age with thousands of channels possible.
scrapser is offline
post #3752 of 3762 Old 05-05-2017, 08:25 AM
rehaz1's Avatar
Quoted: 57 Post(s)
Liked: 31
All of my All of my Harmony remotes are able to handle 4 number channels, this includes my 900, One, Ultimate, Elite, & Touch
rehaz1 is offline
post #3753 of 3762 Old 05-05-2017, 02:47 PM
scrapser's Avatar
Thanks for your reply. Yes, I can enter a 4 digit channel number without any problem. I'm talking about setting up the favorites where you only need to touch the channel icon on the touch screen to go to that channel. My cable service has channels from 1 to 1878 but the favorites setup in the MyHarmony app online only shows up to 999. I cannot select any of the higher channel numbers as a favorite. That is the issue I'm presenting here.
I will point out that I realize many of the channels repeat in several number ranges. That is also not an issue for me.
scrapser is offline
post #3754 of 3762 Old 05-06-2017, 06:58 AM
Tasdom's Avatar
Quoted: 154 Post(s)
Liked: 581
Strange that you can't add 4 digit channels to your favorites. I have several of them in mine. Who's your service provider?
Onkyo Pre/Pro PR-SC5508 & Emotiva XPA-5's x 2
Klipsch RF-7II's Mains RC64II Center RB75's Heights RS-7's Sides RS-52II's Rears
Klipsch RW-12D Subs x 2
Klipsch Belle's
OPPO BDP-105 with Roku Streaming Stick
Epson 6030UB / Vapex 120" Electric Tensioned Screen
Tasdom is offline
post #3755 of 3762 Old 05-06-2017, 01:43 PM
scrapser's Avatar
I reported my issue to Logitech and they have started a resolution ticket. Apparently they need to update their database of providers and what channels are offered in my area. They said it would take 2 to 4 weeks and would contact me again when it was ready.
scrapser is offline
post #3756 of 3762 Old 05-09-2017, 07:35 AM
met64's Avatar
Quoted: 21 Post(s)
Quick question:
I have a harmony ultimate home controlling my family room set up assigned to a specfic hub. I recently hung a tv on our outside patio and want to use Harmony ultimate to control. My question is, the line of sight for both tvs are nearly identical. Only difference, one outside. The only thing separating the two tvs is the windows in family room.
So, will the hubs get confused and control the other TV? I didn't think so, but want to know for sure. Hopefully this scenario makes sense.
Thank you,
met64 is offline
post #3757 of 3762 Old 05-09-2017, 11:30 AM
ahard's Avatar
Quoted: 41 Post(s)
Liked: 29
Originally Posted by met64 View Post
Quick question:
Thank you,
They shouldn't get confused as long as you didn't setup the hubs to control both tvs. Each hub will have it's own name that shouldn't be identical to the other. When you're in the Harmony app you'll have to select the appropriate hub if you want to control it via the app. If you're using Amazon Echo you can use Yonomi for individual of each hub. Without Yonomi Amazon Echo will only recognize one hub per account for voice control unless you create two separate accounts.
XBL: Stunt1on1
ahard is online now
post #3758 of 3762 Old 05-09-2017, 03:04 PM
met64's Avatar
Quoted: 21 Post(s)
Thank you for your response. Very helpful!
met64 is offline
post #3759 of 3762 Old 05-11-2017, 09:39 AM
Ronman79's Avatar
Quoted: 251 Post(s)
Liked: 179
Question Harmony not powering off JVC projector...
I have an Elite and Hub unit. The system will power down my projector with all but ONE activity - the Shield TV activity...I've tried multiple JVC projector codes, adding delays, changing order of power off, etc... Can't seem to get it to work with this one Activity. Afterward, it will power off if I use the "Fix" command...
Any help is greatly appreciated...thanks so much!!!
Equipment List: Theater - JVC DLA-X770R / Denon X4300H / Oppo 203 4K BD Player / Polk Audio RTiA9 Towers / Polk CSiA6 Center / Polk 65RT (6), FXi5 (2) Atmos and Surrounds / (4) Polk PSW505 12" Subs / Nvidia Shield TV / Dish Hopper 3 - 4K/ XBOX One S / Harmony Elite / Echo Dot / Tripp Lite USB / Furman Conditioner / Philips Hue Lighting / Monoprice Cabling
Ronman79 is offline
post #3760 of 3762 Old 05-12-2017, 11:51 AM
rehaz1's Avatar
Quoted: 57 Post(s)
Liked: 31
Try increasing the Inter-device delay for projector
Ronman79 likes this.
rehaz1 is offline
post #3761 of 3762 Old 05-12-2017, 10:46 PM
Ronman79's Avatar
Quoted: 251 Post(s)
Liked: 179
Got it working by adding an extreme delay before starting turn off of the projector. Thanks!
Sent from my SM-G955U using Tapatalk
Ronman79 is offline
post #3762 of 3762 Unread Today, 09:39 AM
mroot's Avatar
A question for those using a Harmony Remote with their LG OLED65B7P (or something like it). I am using the Ultimate with hub, along with a Smart Control remote.
When you select the TV for programming, did you select TV or Smart TV? I'm wondering how it handles using the built-in apps along with ARC back to the A/V receiver.
LG OLED65B7P television
LG UP970 4K Ultra HD Bluray Player
Yamaha RX-V483 receiver
Apple ATV4
mroot is online now
Reply Remote Control Area
Logitech 915 000201 Harmony Ultimate Remote , Logitech 915 000194 Harmony Smart Control
