Harmony Ultimate, Smart Control and Hub - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 123Likes
post #721 of 3721 Old 09-11-2013, 08:00 AM
rehaz1's Avatar
Quoted: 54 Post(s)
Liked: 30
Originally Posted by sanderdvd View Post
Hi guys,
After having a HR 900 for 3 years it was time to make a switch. So I bought the HR Ultimate. My Harmony works quite different then the Harmony Remote Software that the 900 used. I will post some questions in this topic when I m on my way setting up my Ultimate. First thing I encountered is a problem with removing buttons:
When I go to the DISPLAY BUTTONS (so the touch screen) of a device I want to remove some of them. So what I do is click on the X and the display command is removed. After this I click on OK and I update my remote. Problem is that the commands are still there. Strangely is also that when I go back to the buttons menu they are back there. Removing them again does not help, they keep coming back.
What am I doing wrong here?
Also, can I re-order my device list?
It is not possible to remove commands from buttons and leave them blank. A user on the Logitech form, suggested creating a one command Sequence, assignig it to the button, sync the remote, then go back and delete the Sequence and sync the remote again.
rehaz1 is offline
post #722 of 3721 Old 09-11-2013, 12:07 PM
sanderdvd's Avatar
Quoted: 163 Post(s)
Liked: 30
Thanks for your reply. I m not sure i m following you. Do you mean that i cannot remove some (or all) default screen buttons on the Ultimate?!?!?!? If so, i will bring it back immediately. I don t need all the (unneccesary) screen buttons on most of my devices i use!
sanderdvd is offline
post #723 of 3721 Old 09-11-2013, 12:31 PM
meoge's Avatar
If you are just wanting to remove buttons from touch screen then I would just do it from the remote. It's the easiest way. You should be able to remove any default screen button you want.
meoge is offline
post #724 of 3721 Old 09-11-2013, 12:38 PM
sanderdvd's Avatar
Quoted: 163 Post(s)
Liked: 30
How do I do that?
When I go to HOME on my remote I choose one of my devices and at click on MENU, EDIT but there I can only change the order/position of the buttons
post #725 of 3721 Old 09-11-2013, 12:52 PM
HarmonySylvain's Avatar
Quoted: 105 Post(s)
Liked: 52
Hi guys,
Hi sanderdvd,
What you are experiencing is actually a bug in our MyHarmony platform. Changes to device mode screen commands made on MyHarmony should be saved but they currently are not.
This will be fixed in our next release. In them meantime, it is possible to reorder the commands directly on your Ultimate and bring the most used ones to the top, as you have already found.
We apologize for the inconvenience!
Sylvain
I am an employee of Logitech's Harmony division.
Click here to join the Harmony Beta Community!
For questions, help or support, please visit Harmony's support site
HarmonySylvain is offline
post #726 of 3721 Old 09-11-2013, 01:17 PM
sanderdvd's Avatar
Quoted: 163 Post(s)
Liked: 30
Originally Posted by HarmonySylvain View Post
Hi sanderdvd,
Sylvain
thanks for your reply Logitech. When is expected release date of the next My Harmony? And why says meoge that I can remove them from my remote directly? It seems that this is not possible with my HR Ultimate
And can I change the order of my devices list?
post #727 of 3721 Old 09-12-2013, 10:01 AM
rehaz1's Avatar
Quoted: 54 Post(s)
Liked: 30
With all Harmony remotes, it is not possible to re-order devices.
rehaz1 is offline
post #728 of 3721 Old 09-12-2013, 11:09 AM
PGT FTW's Avatar
Quoted: 13 Post(s)
Liked: 25
Hi PGT FTW,
You can expect to see a tablet app (Apple and Android, including the Nexus 7) in late fall of this year.
Regards
Sylvain
Thank you! I asked the same question on the Logitech forum and was told Logitech won't comment on future releases. smile.gif
PGT FTW is offline
post #729 of 3721 Old 09-12-2013, 11:13 AM
meoge's Avatar
Sorry, I thought you were trying to remove buttons from a activity, not a device.
meoge is offline
post #730 of 3721 Old 09-12-2013, 04:59 PM
filefish's Avatar
I like that I can now name the hubs, I am going back to locations with multiple ultimate’s now and giving my customers the app on their smartphones.
Is there a way to lock end users from the "[strike]fix[/strike] break it myself" feature? Any plans to make that feature optional?
filefish is offline
post #731 of 3721 Old 09-13-2013, 08:55 AM
sanderdvd's Avatar
Quoted: 163 Post(s)
Liked: 30
hmmm, that s a pity.
And it also makes no sense to add them all again from the beginning and add them in a different order?
post #732 of 3721 Old 09-13-2013, 09:40 AM
politby's Avatar
Quoted: 76 Post(s)
Liked: 77
I really would love to get this remote. Unfortunately I have a large Z-wave system that I currently control via WiFi using iRule, and of course the Logitech does not do IP.
But I do have a HTPC so I thought maybe the Harmony could send IR to the HTPC and it could send commands to my Vera Lite controller. Anyone know if that is possible?
politby is offline
post #733 of 3721 Old 09-13-2013, 11:41 AM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
I don't see why not. I control my HPTC via IR without issue. You'd just need some middle-ware like Event Ghost to snag the IR commands and send out new ones to your other programs/devices via sending keys. It all depends on how the Vera interface works and if it works via keystrokes or OLE.
That's a really cool device, BTW. Looks like I can finally replace all my crappy X10 stuff with something reliable. Thanks for posting!
mdavej is offline
post #734 of 3721 Old 09-14-2013, 02:02 AM
politby's Avatar
Quoted: 76 Post(s)
Liked: 77
Yes, the Vera is one of my better purchases. Rock solid and has not clicked once. I have ~50 z-wave devices and it all works beautifully.
The Vera responds to HTTP commands so it must be possible to do this from the PC.
politby is offline
post #735 of 3721 Old 09-14-2013, 08:28 AM
PGT FTW's Avatar
Quoted: 13 Post(s)
Liked: 25
If my Sony 70" is mounted in the room and the gear and Harmony Smart Control box is in an adjacent walk-in closet with the door closed, will I need to run a cable and mount an IR flasher to the TV? I haven't closed up the holes in the drywall yet so I can still do it....was hoping not to have to fish more cable in.
PGT FTW is offline
post #736 of 3721 Old 09-14-2013, 12:54 PM
PGT FTW's Avatar
Quoted: 13 Post(s)
Liked: 25
Can get this thing to control the Oppo BDP-103. That's an issue as its acting as the preamp. Tried teaching it as well to no avail
PGT FTW is offline
post #737 of 3721 Old 09-14-2013, 01:18 PM
rehaz1's Avatar
Quoted: 54 Post(s)
Liked: 30
To control the TV, you will need to run a cable and add the Mini Blaster to control the TV as the Smart remote sends no IR
rehaz1 is offline
post #738 of 3721 Old 09-14-2013, 01:21 PM
PGT FTW's Avatar
Quoted: 13 Post(s)
Liked: 25
Thanks...figured that out while continuing to set this up (at my parents'). Just need to sort the Oppo now as its the volume control
PGT FTW is offline
post #739 of 3721 Old 09-14-2013, 08:44 PM
PGT FTW's Avatar
Quoted: 13 Post(s)
Liked: 25
So....pretty much left with returning this if I can't get the Oppo BDP-103 programmed. Any suggestions? I tried adding all models of Oppo to see if anything would work, to no avail. The programming database is clearly wrong as it doesn't recognize the Oppo as a BD player.
PGT FTW is offline
post #740 of 3721 Old 09-15-2013, 02:25 AM
politby's Avatar
Quoted: 76 Post(s)
Liked: 77
Quick question for the Logitech reps: are there any plans for IP support in the Hub?
Just being able to send http wget commands to a specific IP address would be great!
politby is offline
post #741 of 3721 Old 09-15-2013, 09:30 AM
Morris Jones's Avatar
I'm using the Harmony Ultimate with my Oppo BD-103. I don't recall doing anything special.
Morris Jones
Monrovia, CA
http://www.whiteoaks.com
Old Town Astronomers: http://www.otastro.org
Morris Jones is offline
post #742 of 3721 Old 09-15-2013, 09:32 AM
Sorry, I see that you're trying to use it for your volume control. Not a configuration I'll ever need.
Morris Jones
Monrovia, CA
post #743 of 3721 Old 09-15-2013, 06:49 PM
PGT FTW's Avatar
Quoted: 13 Post(s)
Liked: 25
I can't control it at all...power, pause, stop, anything. Yours works ok on a Smart Hub? I tried through the app and using the Harmony remote and no dice.
PGT FTW is offline
post #744 of 3721 Old 09-15-2013, 09:05 PM
Yes, I can control it for power, menus, eject, play, pause, FF, Rewind, Top Menu, ... all the regular stuff. I haven't come across anything I couldn't do on the BD-103. I can bring up the setup menu and fuss with that.
Annoyingly, Power is a toggle, instead of having discrete on/off commands. Haven't engineers figured out not to do that yet? (That and rotating through sources instead of discrete selections.)
Mojo
Morris Jones
Monrovia, CA
post #745 of 3721 Old 09-16-2013, 08:29 AM
s.bradford's Avatar
While the supplied remote may not have discrete on/off buttons, every component I have bought over the last ten years has discrete on/off codes... I believe the Oppo ones are:
Off
0000 006D 0022 0002 0157 00AC 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0689 0157 0056 0015 0E94
On
0000 006D 0022 0002 0157 00AC 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0689 0157 0056 0015 0E94
But here is the problem with the current MyHarmony... no way to enter these. They need to fix this, but since the remote remembers on/off states as invoked by activities, they may not consider this a priority. I much prefer my system remote to send discrete off to every component not in use for the current activity. That way, if any device is manually powered up/down (or like my DVD player, shuts itself off after being idle for a half hour), I don't see devices not in use powered back up when changing activities.
s.bradford is offline
post #746 of 3721 Old 09-16-2013, 08:41 AM - Thread Starter
Keith Mickunas's Avatar
Quoted: 103 Post(s)
Liked: 81
While Logitech doesn't allow users to directly enter hex codes such as these, you can send them to tech support and they will add them. I know the discrete codes are already there for the 83, so I wouldn't be surprised if Logitech already supports them for the other Oppo blu-ray players.
Keith Mickunas is offline
post #747 of 3721 Old 09-16-2013, 09:00 AM
mdavej's Avatar
Liked: 940
Ironically, the oldest device of a brand usually has the most complete code set in the Harmony database. Perhaps because it's had longer for folks to upload codes. In any case since all Oppos share the same codes and the 83 profile is the most complete (including discretes), Oppo users should use the 83 profile. AFAICT, Logitech makes no effort to copy codes across models that share the same code sets, even after many years, as is the case with Oppo.
Since the Harmony databases are built mostly from user learns and code submissions, unless some advanced user submits the pronto hex for discretes, they never get added. Over the years, I've submitted several thousand pronto hex codes to Logitech that eventually found their way into the public database for DirecTV, Dish, X10, Toshiba, and others. If I hadn't done this, most of those models would still be missing many discretes and code sets for different addresses.
So, if you have pronto hex, please submit it to Harmony support so everyone can eventually benefit. And if someone posts a model similar to yours that has a complete code set already, please use it.
mdavej is offline
post #748 of 3721 Old 09-16-2013, 09:21 AM
[...] I tried adding all models of Oppo to see if anything would work, to no avail. The programming database is clearly wrong as it doesn't recognize the Oppo as a BD player.
When I added the device to my Ultimate, I selected manufacturer "Opp" model no. "BD-103". It warned that there were different versions of the codes (I suppose for multiple machines and multiple remotes). I ignored the warnings, and it worked perfectly.
It is a little strange that it's listed as "Oppo Home Theater" and not a Blu-ray player. Doesn't matter, it works fine.
It's nice to see that there is a discrete on/off code set. That is particularly important for a disc player, where one might often walk up to the player, open the drawer, and put in a disc, before ever starting the "activity" related to it. So Logitech ... this one is kind of important.
Mojo
Morris Jones
Monrovia, CA
post #749 of 3721 Old 09-16-2013, 10:18 AM
s.bradford's Avatar
Keith,
While I agree that Logitech support may add codes you send them, I'd much prefer a way to enter them directly. And learned codes are often degraded, so its always better to use the actual codes if you have them.
post #750 of 3721 Old 09-16-2013, 10:44 AM
politby's Avatar
Quoted: 76 Post(s)
Liked: 77
Quick question: can I power the hub from a USB port on my HTPC? Or will it be confused and go into some maintenance mode?
politby is offline
Reply Remote Control Area
Logitech 915 000201 Harmony Ultimate Remote , Logitech 915 000194 Harmony Smart Control
