Harmony Ultimate, Smart Control and Hub - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 123Likes
Old 10-21-2013, 11:48 AM
0db
0db's Avatar
Originally Posted by HarmonySylvain View Post
Thanks for the update 0db - I've passed this over to our device data guys for them to see what's up!
I suspect it's just a case of the same cheap electronics being sold under several names and left for the user to figure out... I was actually pretty impressed when MyHarmony figured out what it was and got it working for me!
0db is offline
Old 10-21-2013, 12:00 PM
HarmonySylvain's Avatar
Quoted: 105 Post(s)
Liked: 52
Originally Posted by politby View Post
My Harmony Ultimate has suddenly developed a small glitch: the backlight never shuts off and the little animation at the top row of the display is constantly moving.
I have not changed the timeout setting, it is set to the default 10 seconds.
I tried a re-synchronization but it did not help.
Is there an easy fix for this or should I RMA?
Hi politby,
You may also want to try rebooting your remote. To do this, press and hole the OFF button for approx 10 seconds, or until the screen powers off and on again. The remote is likely stuck in a weird state -- hopefully that will help!
Sylvain
I am an employee of Logitech's Harmony division.
Click here to join the Harmony Beta Community!
For questions, help or support, please visit Harmony's support site
HarmonySylvain is offline
Old 10-21-2013, 12:06 PM
Quoted: 105 Post(s)
Liked: 52
Originally Posted by jong1 View Post
Loving my Ultimate. A great replacement for my 900. No problem with the repositioned playback controls, despite it seeming a bit "odd". My only gripe is with the missing number buttons which me often need to put in our parental PIN for TiVo. It would be great if there were at least a dedicated button for the number pad, like Favorites or Home, or even if a long press of one of those brought it up, but it's a relatively small thing on a great remote.
Hi jong1,
A possible workaround to rapidly access the number screen would be to set it as your default startup screen. That way, whenever you need to access the numbers, you can tap Home, select your Activity, and you will be on the numbers screen.
To change your Activity startup screen, tap Menu >> Settings >> Activities >> Startup Screen on your remote.
I understand this is a bit of a workaround, but hopefully it will help smile.gif
Regards
Sylvain
Old 10-21-2013, 12:07 PM
Quoted: 105 Post(s)
Liked: 52
Originally Posted by mdavej View Post
Yes, this is what I wanted you to confirm. This is good to hear.
I'll try to provide some examples later. But think of your power and input state tracking as flags that the user cannot access. If the user could set and test his own flags, he could track other things and make decisions in macros (sequences)
Yes. I realize this will require totally new hardware like RS-232 interfaces, etc.
I understand they may withhold this information for that purpose, but years later when the vendor and customer no longer have a relationship, the customer should be able to recover his settings rather than start from scratch. This is a very common request in your forum.
Exactly like that. But you could enhance it and allow the user to configure it anyway he likes (create any groups of screens with any names)
These are just wishlist items. The software is perfectly usable by most people as it is.
Thanks for clarifying mdavej!
Old 10-21-2013, 03:17 PM
Mikeclough24's Avatar
Quoted: 72 Post(s)
Liked: 29
(edited for typos)
Hi Mikeclough24
To leave devices on between Activities and only power it off when the Off button is pressed, select your device in your MyHarmony account and click Change Device Settings >> Power Settings >> I want to keep this device on when switching Activities and only turn it off when I press the Off button. Don't forget to sync your remote to apply this change!
(For those unfamiliar with this feature, this is a recent addition to MyHarmony that is useful when, for example, wanting to switch from a Play Game Activity over to Watch TV to check the news or a game score. Setting your Game Console to remain on between Activities will not power it off and cause you to lose your in-game status.)
Sylvain
Even on the new myharmony? I always did that with my old harmony one but couldnt find this device settings option on the new harmony software. Im at work at the moment but i will look again as soon as i get home.
Mike Clough #24
Mikeclough24 is offline
Old 10-21-2013, 06:40 PM
smr06's Avatar
Thanks also smr06! I've made note of these requests. These also all make sense, just one comment about
>Be able to set repeat bits and command duration on a per-command basis
>-- for example, WDTV-Live has two OFF durations, one for standby and one for full off.
>Currently the only way to change the duration is via Logitech Support.
Durations can be changed at the device level in MyHarmony - go to Device >> Change device settings >> Power Settings >> and keepo your defaults until you reach the Power on / off commands screen. Here you can set the duration for your power commands. I understand this isn't flexbile enough to cater to the different needs each Activity may have, but hopefully is a good enough workaround to get you what you need!
Regards
Sylvain
I will give this a try and see if it works for me.
Wish list:
- Flags, variables, conditional branching, feedback (I don't expect this to ever happen as it would be a pretty huge undertaking, but thought I'd put it out there)
Would you be able to provide a few examples of flags and variables put in day to day Harmony use to help me understand, please?
I'm not mdavej but here's one use case for variables and flags:
When watching TV via a set-top box (for example), there are times when you wish to keep the AVR off, and just use the TV speakers for casual listening; at other times you want to turn on the AVR and get the full 5.1 treatment. (This is easy enough, since recent AVRs have HDMI pass-through -- and some can switch sources via user input even when in standby mode).
Currently the "official" way of doing this within Harmony is to create separate activities for each case -- but that leads to a proliferation of activities, and associated user overhead. Not to mention, the 6-activity limit for the Smart Control (hard remote).
A better way would be to have one activity cover both cases, and have a macro to toggle the AVR power. If the AVR is off, the volume buttons control the TV; if the AVR is on, the volume buttons control the AVR.
Code:
[Macro (softkey)]:   If AVR is OFF, then [AVR.PowerOn, set input to cable box];  else, [AVR.PowerOff].
[Volume +]:          If AVR is OFF, then [TV.Volume +];  else [AVR.Volume +].
[Volume -]:          If AVR is OFF, then [TV.Volume - ]; else [AVR.Volume -].
[Mute]:              If AVR is OFF, then [TV.Mute];      else [AVR.Mute].
I'm sure there are other use cases. How to integrate such functionality into the programming UI, in a way that is not confusing to the user -- that is an open question :-)
--smr06
smr06 is offline
Old 10-21-2013, 07:01 PM
Monger's Avatar
Liked: 66
I tried a search and didn't see anything. I currently have an old 890 I've been using but a few of the number buttons aren't working well and it's probably time to move on. One problem I have had with it is that with my directv hd dvr, HR24 I think, I get a lot of 2 key presses where the guide or list will jump up in multiples making it a pain to get the show I really want. It seems to have been a common issue and I wonder if this is still a problem with the Ultimate?
Monger is offline
Old 10-21-2013, 11:03 PM
jalyst's Avatar
Originally Posted by Keith Mickunas View Post
If you look back at the beginning of this thread you'll see that a lot of people had concerns about the lack of certain buttons and some other features of the Ultimate, but those comments have died off, and mainly come from people that haven't used it. Also, the software has matured quite a bit since it's release.
Yeah, I had detected that much, I'll start a dedicated thread later for more thorough analysis & input from others...
Not 100% convinced that it or one of the Harmony's are a better option than one of the "pro" remotes, but not a huge priority ATM.
jalyst is offline
Old 10-22-2013, 09:43 AM
rehaz1's Avatar
Quoted: 54 Post(s)
Liked: 30
Try reducing the repeats
rehaz1 is offline
Old 10-22-2013, 12:48 PM
den110's Avatar
Didn't buy this remote yet. Does anyone know if the database of codes contain ones for the Lutron RadioRa 600L light switches?
"It's time to nut up or shut up."
den110 is offline
Old 10-22-2013, 01:20 PM
jong1's Avatar
Quoted: 131 Post(s)
Liked: 105
Hi jong1,
Regards
Sylvain
Thanks Sylvain,
Sadly that will not really help as the majority of the time the favourites are exactly what we want after starting the activity. From there it is two swipes to the number screen, which is needed most of the time we want to watch a recorded show (for PIN). A way to set a screen to show when long pressing either the home or favourites button (probably favourites) might be a nice solution.
jong1 is offline
Old 10-22-2013, 01:25 PM
mdavej's Avatar
Quoted: 2128 Post(s)
Liked: 940
Just put the pin in a sequence.
mdavej is offline
Old 10-22-2013, 01:37 PM
jong1's Avatar
Quoted: 131 Post(s)
Liked: 105
Thanks, but then its hardly a PIN! How long do you think it would take our kids to work that one out? smile.gif
jong1 is offline
Old 10-22-2013, 01:50 PM
Monger's Avatar
Liked: 66
Tried that, but it doesn't seem to matter what I set it to.
Monger is offline
Old 10-22-2013, 02:12 PM
jong1's Avatar
Quoted: 131 Post(s)
Liked: 105
Monger you should get onto support and get your problem escalated to 3rd line (back in Canada I think. At least they were).
There has never been a problem like that that they have not been able to fix for me - on my 895, my 900, and most recently, just today, with my new Ultimate. Once you get to them they are amazing.
jong1 is offline
Old 10-22-2013, 03:12 PM
mdavej's Avatar
Liked: 940
I used it for years, and my kids never figured it out (that I know of). Just give it a creative name like "Factory Defaults" or "Business Channel". Each of my activities has several pages of commands, and nobody ever goes past the first page in my house. They'd rather ask me than hunt for anything.
mdavej is offline
Old 10-22-2013, 03:34 PM
jong1's Avatar
Quoted: 131 Post(s)
Liked: 105
smile.gif mdavej, its an elegant amusing solution. Still I trust the first time my son sees me press only one button for the pin he'll work it out!
Thanks for the idea, but I still think it would be good to have a fast way to the digits (for other purposes too), given they are so easy to access on 95% of remotes, which have separate buttons for them!
jong1 is offline
Old 10-22-2013, 04:17 PM
Quoted: 105 Post(s)
Liked: 52
This feature actually works better on MyHarmony.
On the Desktop version, this setting applied to the whole Activity, whereas MyHarmony lets you decide which individual devices should behave like this.
Sylvain
Old 10-23-2013, 09:24 PM
Dualsub2006's Avatar
Lutron RA-600L is in the database.
Sent from my Galaxy Nexus using Tapatalk
Dualsub2006 is offline
Old 10-24-2013, 06:53 AM
jong1's Avatar
Quoted: 131 Post(s)
Liked: 105
Code:
--smr06
Took me a while to get round to this but +1 to this request. It is probably the biggest quality of life improvement you could make to my remote!
jong1 is offline
Old 10-25-2013, 11:56 AM
jTemplar's Avatar
Hi
I am using a Harmony Smart Control Hub & Remote on firmware version 3.3.34
I would like to set an activity with my TV included but not powered-on. The reason is because I want to use the radio feature of one of the other devices in the activity which also has a TV picture output. I would like to be able to power-on the TV should I need to see the radio guide of that device on my TV.
In order to be able to power-on the TV I need to add it to the activity to set buttons on the remote but do not want the TV to power-on unless needed; I will set one of the buttons as power toggle.
Is it possible to add devices to activities without having them power-on?
jTemplar is offline
Old 10-25-2013, 04:48 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
Originally Posted by jTemplar View Post
Hi
The easiest way would be to teach the "power" command from the original TV remote to one of the devices already in your activity (i.e. AVR). You can name it "TV POWER" and then add that command to any free button in your activity. Just remember, when you use that button you are essentially doing it "behind the remote's back" so it does not know that the TV has been turned on, and therefore will not turn it back off when you hit the "OFF" button.
jTemplar likes this.
Dropkick Murphy is offline
Old 10-25-2013, 05:05 PM
jTemplar's Avatar
jTemplar is offline
Old 10-26-2013, 03:15 AM
jTemplar's Avatar
Unfortunately the solution suggested by Dropkick Murphy doesn't work for me as despite teaching the power command from the original TV remote to one of the devices already in my activity and naming it "TV POWER" and then adding that command to a free button in my activity it tries but does not manage to power-on the TV. My Panasonic TV needs the power button to be pressed and held for a couple of seconds before it will power-on.
I remember when setting-up this TV with my first Harmony remote back in 2007 having to call technical support because of the same issue and they managed to do something which extended the longevity of the power IR so managing to power-on my TV. Because I imported all my settings to the Harmony Smart it is able to power-on my TV within activities which have the TV included but I cannot access that command nor teach it to my new Smart.
I guess I will have to call Technical Support again.
jTemplar is offline
Old 10-26-2013, 11:45 AM
johnchipman's Avatar
Hi there, need some help with my hub. I just upgraded my router but i can't figure out how to connect the hub to the new network. I need to make some adjustments to my activities, but it won't let me because the hub isn't on the new network. I have the smart control system. Help!
johnchipman is offline
Old 10-27-2013, 05:11 PM
gavone1976's Avatar
my remote is stuck with x's next to all the favorites and will not let me do any thing else.
Please help!!
SYNC on the MYHARMONY website does nothing
gavone1976 is offline
Old 10-27-2013, 07:10 PM
When I watch a bluray movie on the PS3, there is that popup menu showing all the different options like pause play volume, menu, etc. How do I remove the on screen display by default?
413X3 is offline
Old 10-28-2013, 05:13 AM
Mike V's Avatar
OK, I've read 20 pages and cannot find my answer so I'm going to ask.
I have the smart Control. Is there volume punch through?
I cannot control my master volume when on the DVD or cable box pages of the app. I need to go to devices, and select the processor to do it.
Mike V is offline
Old 10-28-2013, 06:50 AM
mdavej's Avatar
Liked: 940
Not in device mode, only in activity mode. All Harmony's work that way.
mdavej is offline
Old 10-28-2013, 09:36 AM
It has something to do with the ps3 thinking there is no controller so it gives me an on screen display for bluray movies. There must be a way to turn this off or disable it. It didn't happen with my Harmony One, just the Harmony Ultimate.
413X3 is offline
Logitech 915 000201 Harmony Ultimate Remote , Logitech 915 000194 Harmony Smart Control
