Harmony Ultimate, Smart Control and Hub - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 126Likes
post #991 of 3743 Old 11-09-2013, 11:35 AM
ArmCapp's Avatar
Originally Posted by DoctorVideo View Post
From what I have heard, even if your components are on separate shelves, as long as they are in the same cabinet, the IR from the hab will reach all the components, as the signal bounces all around the inside of the cabinet. My components are in several separate cabinets in an entertainment center, but all have glass doors, so I positioned my hub directly across the room, and it works great.
Thanks for the info DoctorVideo.
Also someone on the Logitech forum mentioned these http://www.logitech.com/en-us/product/6230?crid=1052 IR extender cables. I guess I can try the mini blasters and if they don't work I'll buy the extender cables.
ArmCapp is offline
post #992 of 3743 Old 11-09-2013, 12:50 PM
dvdmd1's Avatar
Quoted: 34 Post(s)
Liked: 43
Try Holding down the off and menu button which does a hard reset,then re sync it
dvdmd1 is online now
post #993 of 3743 Old 11-10-2013, 08:17 AM
insync44's Avatar
Quoted: 23 Post(s)
Does anyone know if the Smart Control will work with the new PS4 and does my 900 become a paperweight until logitech issue a new adapter?
insync44 is offline
post #994 of 3743 Old 11-10-2013, 01:21 PM
hltr's Avatar
Liked: 25
By the way....the latest firmware gives additional control for Hue lights....
____________________
Brian's Bar Build
hltr is online now
post #995 of 3743 Old 11-11-2013, 06:47 AM
rehaz1's Avatar
Quoted: 56 Post(s)
Liked: 30
Presently, no Harmony remote is designed to work with the new PS4
rehaz1 is offline
post #996 of 3743 Old 11-11-2013, 09:08 AM
HarmonySylvain's Avatar
Quoted: 105 Post(s)
Liked: 52
Originally Posted by Linda View Post
I sent off a request to Logitech support but figured I'd post here in case anyone else has seen this happen...
I picked up my Ultimate off the cradle and the touchscreen was moving from screen to screen as if ghostly fingers were touching buttons. It wouldn't listen to my actual physical touches but kept flashing through screens.
I tried unplugging the hub and the remote stopped displaying the "unable to communicate with hub" screen. When I plugged the hub back in it resumed it's mad, possessed, behavior.
Next I tried rebooting the remote by holding down the Off button but the problem began again.
I'm suspecting something has gone wrong in the touch screen hardware but I'm hoping there is some sort of reset or recalibration procedure which might do the trick.
Anyone seen this happen?
Hi Linda
You may also want to try a factory reset on your remote - this is the same procedure as a remote reset but holding the Off and Menu buttons pressed. You will need to resync your remote once this is done.
Good luck!
I am an employee of Logitech's Harmony division.
Click here to join the Harmony Beta Community!
For questions, help or support, please visit Harmony's support site
HarmonySylvain is offline
post #997 of 3743 Old 11-11-2013, 09:12 AM
Quoted: 105 Post(s)
Liked: 52
Regarding PS4 and Xbox One control, I believe we reached out to Sony and Microsoft to better understand how their new consoles would work, and haven't heard back yet.
..but rest assured that if these consoles remain Bluetooth or IR controlled, we'll support them once we figure out the commands they use.
post #998 of 3743 Old 11-12-2013, 08:29 AM
scootss's Avatar
I know from the excellent FAQ that the RF is good, but doesn't work reliably between floors.
I think the answer to this is no...but...
Is it possible for the ultimate to talk to the hub via WIFI instead of RF? Essentially, I'm looking for the range of wi-fi (which I could achieve from the iphone app), but I need physical buttons. (or more correctly, my wife needs a remote with physical buttons).
any thoughts? If harmony isn't the way to go with this, other suggestions are welcomed!
Additional background...9 year apartment dwelling harmony user moving to a new house and acheiving his dream of whole house distributed AV from a beautiful rack in the basement ;-)
scootss is offline
post #999 of 3743 Old 11-12-2013, 08:58 AM - Thread Starter
Keith Mickunas's Avatar
Quoted: 104 Post(s)
Liked: 81
Do you have any CAT5 run or is it possible to run some? If so, then you could place the hub upstairs and use CAT5 to run emitters down to the rack.
Placing the Hub downstairs might work, it just depends on your arrangement. For instance I would bet that if the hub was located directly below the room you were using the remote in it would be fine. I have a two story house, no basement, and the hub is placed in an enclosed steel rack on the second floor over the garage. So when I go downstairs and try to use the remote I'm pretty far from the hub and going through a number of obstacles.
Keith Mickunas is offline
post #1000 of 3743 Old 11-12-2013, 09:35 AM
Quoted: 105 Post(s)
Liked: 52
Edited to correct typos
Hello everyone
As of this morning PST, a new Harmony app is available on the Apple Store and Google Play. This new version requires (and will push) a new firmware update (v3.4) onto your hub.
Harmony App v3.0 for iOS and Android
Tablet version
Tablet support now provides a dual pane view of Activity controls
Support for portrait and landscape orientation
Hue
Discover and pair with hue bridges from the Settings menu
Control lights individually or in groups
Adjust individual bulb brightness and color temperature
Added the ability to customize the behavior of a long-press on the bulb button.
Misc
Harmony Ultimate users can now also access and edit device, Activity, Favorites and other settings from the Harmony app (previously Smart Control only)
Activity icons customized on MyHarmony now appear in the app
Screen dims to save battery when Auto-lock is disabled.
Fixed general bugs
Enjoy!
Sylvain
post #1001 of 3743 Old 11-12-2013, 10:33 AM
scootss's Avatar
Yes! That could be a good solution. Thank you!
You also made me realize another possibility...
As of now, I'm thinking about using a hdmi matrix over ethernet to bring hdmi to the TVs. This Octava (http://www.octavainc.com/HDMI_Matrix_HDbaseT_HD4xSTPMX_over%20CAT6.html) will retransmit IR. So perhaps I can just use the harmony over IR only, with those signals being retransmitted over the octava to the rack in the basement.
scootss is offline
post #1002 of 3743 Old 11-12-2013, 10:46 AM
jnnt29's Avatar
Quoted: 119 Post(s)
Liked: 132
Originally Posted by HarmonySylvain View Post
Hello everyone
Harmony App v3.0 for iOS and Androis
Tablet version
Hue
Misc
Fixed general bugs
Enjoy!
Sylvain
Thank you Sylvain!
My set up
Marantz SR-7008, Emotiva XPA-3
Samsung UBD-K8500 Ultra 4K Blu Ray Player
Klipsch RB-81II, RC-52II, Boston Acoustics Micro 120s
Klipsch SW-310, RPW-10, Samsung UN65JS8500FXZA
http://www.avsforum.com/avs-vb/showthread.php?t=1227096
jnnt29 is offline
post #1003 of 3743 Old 11-12-2013, 07:09 PM
jnnt29's Avatar
Quoted: 119 Post(s)
Liked: 132
Sylvain the updates to the IOS for the iPad is much better... Thanks
My set up
jnnt29 is offline
post #1004 of 3743 Old 11-14-2013, 04:46 PM
mangothehuman's Avatar
Anyone else have a problem with the remote not working for about 5 minutes or so when you first turn on your TV? It's not because the components need to warm up. I never had this problem before I bought the remote. It looks like the hub is getting the signal (it's flashing), but the channel won't change and all of the other buttons except for the power and volume don't work or if they do work, they don't send a strong signal. So, instead of changing the channel to 1602, I end up on channel 6 or 1.
Help!
mangothehuman is offline
post #1005 of 3743 Old 11-14-2013, 10:29 PM
ffrcoupe's Avatar
This might not be the thread for this question but here goes.
What is the deal with the device limits on Harmony remotes?
I can understand device limits if the remote has a physical button to switch devices but the Harmony remotes all have a display so there is no issue to switch devices on the screen.
So is there a memory consideration or is it an artificial limitation to buy a more expensive remote to be able to control additional devices? What if someone needs to control 16 devices? Are they SOL?
All this being said, I just ordered a Harmony Ultimate. Woo Hoo!
ffrcoupe is offline
post #1006 of 3743 Old 11-15-2013, 08:05 AM
AndrewFG's Avatar
Quoted: 28 Post(s)
If you have the hub programmed with a start up delay for your TV of 300 seconds, then it will hold off sending any i/r commands to that device until this time has elapsed.
=> Change the start up delay of the device in question to something more appropriate (for example my Sony TV needs a delay of about 15 seconds before it is able to accept i/r commands).
AndrewFG is offline
post #1007 of 3743 Old 11-15-2013, 01:45 PM
indyfred's Avatar
Just a thought, but I think that Harmony's thinking is that if their low-end remotes control so many devices, then why would the customer need to move up to their high-end remotes.....
indyfred is offline
post #1008 of 3743 Old 11-15-2013, 02:09 PM
Sragona's Avatar
The Harmony Smart remote can only do 6 devices because the remote only has 3 source buttons (3 + 3 Long press), so that makes sense to me. For the other ones, I'm sure it's because they want you to buy a nicer one because the hub seems to be the same with all of them.
Sragona is offline
post #1009 of 3743 Old 11-15-2013, 02:10 PM
mdavej's Avatar
Quoted: 2151 Post(s)
Liked: 949
The limit is artificial for the reason above.
mdavej is offline
post #1010 of 3743 Old 11-15-2013, 03:48 PM
ffrcoupe's Avatar
I'm only at 8 devices right now but I still bought the Ultimate for the features.
I'm OK with that but I was just curious.
I guess they have to set a limit and 15 is pretty high but I like 25 better. LOL wink.gif
ffrcoupe is offline
post #1011 of 3743 Old 11-16-2013, 07:27 AM
golfwolf's Avatar
I just picked one of these up for my bedroom. My TV is wall mounted and my cable box and DVD player are in the closet behind the TV. My question is where do I place the hub and IR boosters (and do I need both boosters)? Pic attached.
golfwolf is offline
post #1012 of 3743 Old 11-16-2013, 07:57 AM
DoctorVideo's Avatar
Quoted: 16 Post(s)
Since the components appear to be on an open shelf, I would just place the hub directly across from the cabinet. No boosters needed.
DoctorVideo is offline
post #1013 of 3743 Old 11-16-2013, 08:07 AM
golfwolf's Avatar
Thanks for the quick reply. What about for the TV since it's in the open ? Do I need a blaster/booster for that?
golfwolf is offline
post #1014 of 3743 Old 11-16-2013, 08:52 AM
Quoted: 16 Post(s)
Whoops, I forgot about the TV. Yes, you'll need to run a blaster out to the TV.
post #1015 of 3743 Old 11-16-2013, 09:04 AM
jong1's Avatar
Quoted: 178 Post(s)
Liked: 124
If you are using the Ultimate it is also possible to use its inbuilt IR for the TV. You will need to manually set the remote to use IR instead of the hub for that device.
On the other hand, if you can use a blaster it is good because you no longer need to worry about pointing the remote at the TV, which can be a pain especially with the long power on times of some modern smart TVs.
The blasters are strong, you may well not need to aim at the TV. I ran mine through the same hole in the wall as all the other cables to the TV and mounted the blaster on the wall just under the TV. The signal bounces off the walls and back to the TV perfectly.
jong1 is online now
post #1016 of 3743 Old 11-16-2013, 02:59 PM
eecyclone's Avatar
Help!
I have experienced something similar. I just "recovered" the remote and hub which seemed to fix it. Recovering basically re-sends the remote program and overwrites the bad program on the remote. Doing this fixed my projector's power issues and not being able to control the projector in general.
eecyclone is offline
post #1017 of 3743 Old 11-17-2013, 06:24 AM
rehaz1's Avatar
Quoted: 56 Post(s)
Liked: 30
The Device limit isn't tied to the number of Activities it can preform. My Smart Control remote has 8 devices with 6 Activities
rehaz1 is offline
post #1018 of 3743 Old 11-17-2013, 08:57 AM
yozh's Avatar
So here is a big question for you guys. I have a 900 still sealed in a box. I`m almost done setting my living room AV system and was going to setup 900. I started reading about the Harmony Ultimate and now having doubts if I should go with that instead of the 900, or just get a hub in addition to 900(for iOS/Android control). Here is my setup so far, Yamaha v671, Samsung SmartTV, Samsung smart BD-Player , FIOS STB, RPi OpeneElec (controlled via HDMI-CEC from AMP), GTV revue (mostly not used, wish it had more functionality like hub or does it ?), Roku 2 XS, Wii (very rarely used), insteon (ir link for lights control). I add devices to test from time to time, WDTV, AppleTV etc... I used multiple Harmony remotes before. So the question is should I just get ultimate and skip 900 or should I install 900 and add hub maybe with the smart control as a simple remote for the iOS/Android control ? Any feedback is appreciated !
yozh is offline
post #1019 of 3743 Old 11-17-2013, 11:13 AM
Sragona's Avatar
You're right, I guess I misread the OP as "activities" instead of "devices"...
Sragona is offline
post #1020 of 3743 Old 11-17-2013, 12:02 PM
mdavej's Avatar
Liked: 949
The 900 is incompatible with the hub.
mdavej is offline
Reply Remote Control Area
Logitech 915 000201 Harmony Ultimate Remote , Logitech 915 000194 Harmony Smart Control
