Harmony Ultimate, Smart Control and Hub - Page 46 - AVS Forum | Home Theater Discussions And Reviews
 123Likes
Old 01-07-2014, 07:07 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
Originally Posted by Kimikaze View Post
Thanks, I'll try a device delay, but I don't understand why this only happens occasionally. Also, there are times when the tv starts on component 1 and I can see the cable signal, but then after a second it switches to air input. Again, doesn't happen often, but it does happen.
Just curious is your OEM TV remote has a "toggle" switch for the inputs or dedicated buttons for each input?
CaptMike is offline
Old 01-07-2014, 07:46 AM
Kimikaze's Avatar
It has one button for switching inputs (TV/Video). Pushing it once will bring up the inputs menu on the tv and then each push after that will toggle the input. Alternatively, when the menu appears, I can push a number button corresponding with the input labels to go directly to that input. I can also scroll up and down with the d-pad.
Kimikaze is offline
Old 01-07-2014, 07:50 AM
mdavej's Avatar
Quoted: 2131 Post(s)
Liked: 942
I've never seen an OEM TV remote with discrete input buttons. But many TVs respond to discrete input commands. So the OEM remote buttons are irrelevant. What brand TV do you have?
mdavej is offline
Old 01-07-2014, 09:01 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
I don't think it's a device delay issue
I think it is a discreet IR code issue.
CaptMike is offline
Old 01-07-2014, 09:07 AM
Kimikaze's Avatar
Panasonic TH-50PX50U
Kimikaze is offline
Old 01-07-2014, 09:08 AM
Kimikaze's Avatar
OK. What can I do?
Kimikaze is offline
Old 01-07-2014, 09:13 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
OK. What can I do?
See daves post above regading the make and model of your tv
CaptMike is offline
Old 01-07-2014, 09:23 AM
mdavej's Avatar
Liked: 942
Panny has discrete input codes. So no need to put up with that menu walking nonsense. First, try a different model from the database and see if it has discrete inputs. Failing that, ask Logitech to add the discrete input codes. If they can't find any, I can post them.
In any case, I'd keep the delay at at least 10 seconds.
mdavej is offline
Old 01-07-2014, 11:21 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
MdaveJ, question
I want to confirm my thought on this issue
I have x-10 lighting in the garage in which I want to control from a maxi controller or the IR543.
The problem is one of the ways that I can control that specific light is from the IBM RF remote utilizing an RF receiver also plugged into an outlet in the garage.
The IR543 or the maxi controller does not control that particular light unless I plug either one into an outlet in the garage.
I want to use an IR remote to control that particular light.
What is needed?
CaptMike is offline
Old 01-07-2014, 11:35 AM
mdavej's Avatar
Liked: 942
You need a phase coupler in your fuse box for the IR543 to work on all circuits. X10 used to sell them. I think I still have one somewhere. It takes some intestinal fortitude to install, or an electrician.
EDIT: I almost forgot. There is also a phase coupler you can simply plug into any 240V socket like the one for your dryer or oven.
What it does is allows X10 power line signals from your IR543 to cross phases (most home's electrical is evenly spread over 2 phases). As you already discovered, without this coupler, only devices on the same phase as your IR543 can be controlled from it.
mdavej is offline
Old 01-07-2014, 11:51 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
Thank you
CaptMike is offline
Old 01-07-2014, 12:02 PM
HarmonySylvain's Avatar
Quoted: 105 Post(s)
Liked: 52
Hello everyone and happy new year!
I was on break over the holidays but see that you guys have been keeping busy smile.gif
I'll do my best to go through the last few pages of this thread to answer anything that hasn't been addressed yet, but may miss a question or comment. If that's the case, please feel free to bring it back to my attention, either directly within this thread of by PM.
Sylvain
I am an employee of Logitech's Harmony division.
Click here to join the Harmony Beta Community!
For questions, help or support, please visit Harmony's support site
HarmonySylvain is offline
Old 01-07-2014, 12:42 PM
zamboniman's Avatar
Sylvain
Awesome I'm hoping you can shed some light on my duplicate activity button push issue with the smart control
zamboniman is offline
Old 01-07-2014, 12:51 PM
Quoted: 105 Post(s)
Liked: 52
Hi zamboniman,
Yes! Here we go:
Originally Posted by zamboniman View Post
Well I picked up the smart control thinking (hoping) it was the solution I've been waiting for. Got it all programmed up. Was excited loving the new remote especially the simple hard button remote. Everything is well in the world at 2AM. Morning time I'm all excited to share the joys of new found AV simplicity. Hand the remote to my 2yr old daughter and she stumbles on a HUGE issue in a matter of seconds.
I HOPE there is an easy fix.
Basically if you push an activity button on the hard remote more than once the whole system gets out of sync. If using the app it seems smart enough to "remember" where it was last and you can't "click" an activity twice. However grab that hard remote and one push all is great... another push.. and you're in remote hell. You're scrambling for those remotes now buried in the drawer to get everything back in sync.
Any thoughts on this? Known issue? Workarounds? Fix coming?
So far the "smart remote" was derailed from family acceptance in less than 30 seconds. It's nothing but a wowee novelty currently and not something that can be counted on.
As a side note I've also realized that my older vizio TV that lacks discrete input selection as well as power commands is a limiting factor as well. I've tried a few other models in the setup based on some quick google searching but the TV doesn't seem to accept the newer commands.
Seems like you've found the hidden Help feature on the Smart Control!
Pressing an Activity button again after it has powered on assumes the Activity didn't start correctly, and triggers an algorithm that tries to get your devices back to their correct states. The efficiency of this algorithm depends on how many non-discrete devices are in your Activity, and the Activity button may need to be pressed multiple times in order to get to the correct states. Using it when your Activity has actually started properly will of course, as you say, be disruptive...
Has anyone else noticed this feature? How is it working for you?
Old 01-07-2014, 12:55 PM
Quoted: 105 Post(s)
Liked: 52
Originally Posted by met64 View Post
Did a quick search in this thread and did not see anything. I have been sampling remotes for my bedroom set-up and have been trying the smart control plus hub. The app is completely useless but I do like the hard buttons on the remote. Anyway, I have a Zvox sound bar, that after manually trying to learn the commands plus adding through my harmony I can't get the smart control to operate it's basic functions like power on/off, volume up/down, etc. I emailed Logitech support but figured I would post here to see if anyone has had success with the Zvox 555 speaker w/harmony smart? Thank you in advance!
Hi met64,
The Zvox 555 device is in our database and should not need to be manually added.
Please try deleting the device you added from your account, and adding it again as
Manufacturer: Zvox
Model number: 555
Any Activities using the older, deleted device will need to be set up again to use the new version.
Sylvain
Old 01-07-2014, 12:56 PM
Kimikaze's Avatar
Thanks, mdavej! I'll give that a try and let you guys know how it goes.
Kimikaze is offline
Old 01-07-2014, 12:57 PM
Quoted: 105 Post(s)
Liked: 52
Originally Posted by eday_2010 View Post
Does anyone else have the issue where after syncing, when you select an activity such as "Watch TV", most of the buttons and touch screen commands don't work? This happens to me regularly, and after fiddling around in the Settings and elsewhere, they start working. I would like to get this solved. It would be nice if this new advanced remote functioned as well as my Harmony 890.
Hi eday,
We'd like to take a look at the logs generated by your hub to see if we can find anything related to this issue. Would you mind PMing me your email ID please? Your password is not needed.
Sylvain
Old 01-07-2014, 01:17 PM
Kimikaze's Avatar
Actually, I should mention that when turning on any activity involving the tv, I don't see any menu walking on the screen. It seems to go directly to the assigned input... when it's working correctly, that is.
So how can I tell if a different model has discrete inputs? I'm assuming that I have to go through myharmony.com?
Kimikaze is offline
Old 01-07-2014, 01:24 PM
mdavej's Avatar
Liked: 942
Sorry, I misunderstood then. Sounds like it's already using discretes. Could still be timing, HDMI-CEC (disable that - viera link), or using the wrong input commands. Test each in device mode to confirm they work as described. To get the timing right, turn on the TV and start a timer. Then press vol+ or ch+ constantly. Note the time at which the TV starts to react. That plus 500 ms is your power on delay.
mdavej is offline
Old 01-07-2014, 01:36 PM
met64's Avatar
Quoted: 16 Post(s)
Hi met64,
Manufacturer: Zvox
Model number: 555
Sylvain
Thank you for the reply. I have tried that more than once. I also posted on the LT forum. Where I am now is, I have 4 days left in return window. I basically started completely over and reentered everything, including activities, reset hub, etc. I did this on Sunday this past weekend. Yesterday, Monday it exhibited same issues as before. Intermittent failure of Harmony Smart Control to control the Zvox basic functions (on.off/volume,mute) etc.
When it works, I love it. I am checking again later today and will report back. Could it be, I just have a lemon?
met64 is online now
Old 01-07-2014, 01:42 PM
mdavej's Avatar
Liked: 942
Could be IR interference. How does the original remote work? What kind of TV?
mdavej is offline
Old 01-07-2014, 01:43 PM
zamboniman's Avatar
Hi zamboniman,
Yes! Here we go:
First off THANK YOU for the quick reply!
Arggg! I love hidden "features". I can appreciate the thought of it now that I understand what it's doing and the non predictable behavior with multiple presses. Unfortunately, in my case the perfect storm. A vizio TV with only a power button toggle AND only input toggles. So I can see how your algorithm can create some havoc with my TV settings. ... ending up on wrong inputs then off then a mix of both. The kicker is devices without discrete commands are painful.
That all said. I would really like this "feature" to be allowed to be disabled in advanced programming somewhere. i.e. allow it to be there for some or if desired. But in my case I'd much rather have it work without the "help" algorithm knowing that I have to do some manual "help" intervention if a command gets missed. The reliability of commands getting accepted can be managed to be pretty high with thoughtful emitter placement and tweaking delays etc. I'd surely take the risk of the occasional potential out of sync rather than hand the remote to the kids and often be out of sync with frustrated users.
Old 01-07-2014, 02:30 PM
Quoted: 105 Post(s)
Liked: 52
In addition to mdavej's questions - is the hub properly firing IR when the Zvox is not responding? To check this, view your hub through a digital camera (phone, webcam, etc). When it's actually firing IR signals, you will see a white flash coming from the hub.
Sylvain
Old 01-07-2014, 02:37 PM
Quoted: 105 Post(s)
Liked: 52
Thank you for the feedback zamboniman. It has been noted!
(I haven't responded to each and everyone's thoughts in the last few pages of this thread, but they have also been noted! Thanks everyone!)
Old 01-07-2014, 05:14 PM
bartl007's Avatar
Harmony Sylvain,
Please see post #1325 for more detail.
Is there a known issue with PS3 firmware version 4.53 and the harmony ultimate?
Doesn't seem to be any consistent reports in the LT forum.
Thanks in advance
hltr likes this.
bartl007 is offline
Old 01-07-2014, 06:03 PM
Quoted: 105 Post(s)
Liked: 52
Originally Posted by bartl007 View Post
Harmony Sylvain,
Thanks in advance
Hi bartl007,
There are no known issues between the Ultimate and PS3 on their respective latest firmwares, but I've brought your post to our QA team's attention for further investigation. I'll let you know if anything comes up.
Sylvain
Old 01-08-2014, 11:43 AM
4WR
4WR's Avatar
Hi guys;
I recently installed an Ultimate to replace a ONE that the screen partially crapped out on.
I imported my settings from “Harmony software” to “My Harmony” and all went well but with regards to my Marantz AV-8003 pre-amp a warning told me that input switching MAY need attention. It did not tell me what kind of attention would be required.
The problem is that when starting an activity the Marantz is always either out of sync power wise or on the wrong input. No amount of pushing help or going directly to inputs in device mode will switch to the correct input.
When switching commands away from the hub to the remote it works every time. No matter where I place the hub it still acts this way. All other commands work, as they should.
Any thoughts on what I could try to solve this issue?
Take Care
4WR is offline
Old 01-08-2014, 04:48 PM
met64's Avatar
Quoted: 16 Post(s)
Hi, Thxs for the reply. The TV is Samsung (not sure of model #). And as for the remote, do you mean the Zvox remote?
met64 is online now
Old 01-08-2014, 04:54 PM
met64's Avatar
Quoted: 16 Post(s)
Sylvain
Thxs for the reply. It seems at least for the last 2 days the Harmony Smart is working great with all my gear including the Zvox. I deleted everything, and reentered all info and rest the hub again, and it seems to be working as it should. But to answer your question, I can see the white flashing. I don't know why all of a sudden it is working. The only thing I did differently was move the repeater a few feet from where it was positioned before.
met64 is online now
Old 01-08-2014, 07:07 PM
fcwilt's Avatar
Quoted: 43 Post(s)
Liked: 26
Repeater???
What do you mean?
Regards, Frederick C. Wilt
fcwilt is offline
Logitech 915 000201 Harmony Ultimate Remote , Logitech 915 000194 Harmony Smart Control
