Harmony Ultimate, Smart Control and Hub - Page 58 - AVS Forum | Home Theater Discussions And Reviews
 128Likes
post #1711 of 3762 Old 02-21-2014, 11:38 PM
Redfin's Avatar
It sure is a hard habit to break: pointing the remote at the TV. smile.gif
Redfin is offline
post #1712 of 3762 Old 03-01-2014, 01:49 PM
scrapser's Avatar
Does the Ultimate have the same problem as previous remotes where the coating wears off the buttons from your fingernails? I can barely discern the symbols on some of my buttons anymore. Kind of a dumb idea on Logitech's part to make the buttons so fragile.
scrapser is offline
post #1713 of 3762 Old 03-01-2014, 01:59 PM - Thread Starter
Keith Mickunas's Avatar
Quoted: 104 Post(s)
Liked: 81
Well I've had mine since around the time it was initially released, and there's no wear yet. However I don't use my fingernails as that would be really awkward for me to do.
Keith Mickunas is offline
post #1714 of 3762 Old 03-01-2014, 02:03 PM
scrapser's Avatar
I'm a male. I don't bite my nails so how long they are depends on when I last clipped them. I generally don't use my fingernails to push buttons either but sometimes you hit one button while pressing another and stuff like that. I think unless you keep your nails really short it's inevitable you will hit a button with them occasionally.
scrapser is offline
post #1715 of 3762 Old 03-03-2014, 08:10 AM
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
So what are you guys doing about turing on your tvs that bought the smart control? I really need IR for that but I dont want to have an ir wire hanging in front of the tv. I dont need all the bells of whistles of the ultimate either.
wraunch is offline
post #1716 of 3762 Old 03-04-2014, 05:42 AM
Dropkick Murphy's Avatar
Quoted: 72 Post(s)
Liked: 89
Two choices:
#1 Put an IR blaster in front of the TV
#2 Turn it on manually
Dropkick Murphy is offline
post #1717 of 3762 Old 03-04-2014, 08:56 AM
DoctorVideo's Avatar
Quoted: 16 Post(s)
I have my hub positioned across the room, on an end table, next to the couch.
DoctorVideo is offline
post #1718 of 3762 Old 03-04-2014, 02:36 PM
HarmonySylvain's Avatar
Quoted: 106 Post(s)
Liked: 52
Hello everyone,
Harmony released Hub FW 3.7.37 today, which contains many improvements to the disconnection issues people have been reporting.
This firmware will install automatically the next time you sync your Harmony Smart Control, Ultimate or Ultimate Hub.
We'll continue to work with people who still experience issues after installing this new firmware, so please reach out via PM either here on to the HarmonyTeam on our official support boards if you continue to experience problems.
Regards to all,
Sylvain
I am an employee of Logitech's Harmony division.
Click here to join the Harmony Beta Community!
For questions, help or support, please visit Harmony's support site
HarmonySylvain is offline
post #1719 of 3762 Old 03-04-2014, 03:31 PM
artur9's Avatar
Quoted: 621 Post(s)
Liked: 217
My hub is sitting on the table in front of the TV. The TV is hanging on the wall.
artur9 is offline
post #1720 of 3762 Old 03-04-2014, 03:32 PM
artur9's Avatar
Quoted: 621 Post(s)
Liked: 217
Originally Posted by HarmonySylvain View Post
Hello everyone,
Is this for the hub losing its connection to the wifi, the remote losing its connection to the hub or something else?
thanks, and, BTW, it's awesome your presence on the board.
artur9 is offline
post #1721 of 3762 Old 03-04-2014, 04:09 PM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
I guess it really does not matter because the the upgrade will be done when you sync whether you want it or not.
CaptMike is offline
post #1722 of 3762 Old 03-04-2014, 07:30 PM
Mikeclough24's Avatar
Quoted: 85 Post(s)
Liked: 29
I spilled some beer on my ultimate and a few of the buttons now stick! mad.gifmad.gifmad.gif
Anyone know of a good way to clean it safely? It's pretty depressing.
Mike Clough #24
Mikeclough24 is offline
post #1723 of 3762 Old 03-05-2014, 09:31 AM
space2001's Avatar
Quoted: 65 Post(s)
Liked: 37
any chance we will be able to control pc over ip at some point?
space2001 is online now
post #1724 of 3762 Old 03-05-2014, 11:36 AM
Toknowshita's Avatar
Quoted: 37 Post(s)
Liked: 49
Anyone have a similar experience where the top portion of the touch screen on the Ultimate or Touch is intermittently responsive. I don't know if it's normal behavior. It seems to sometimes not sense a touch on the top left of the screen when an activity button is present.
Toknowshita is offline
post #1725 of 3762 Old 03-06-2014, 05:34 AM
eecyclone's Avatar
Originally Posted by Redfin View Post
I saw some earlier questions about the Ultimate and Lutron IR dimmers, as a new owner of the Ultimate, I can unequivocally state that it works as advertised. I didn't have to "learn" the codes, it found my model right away for on, off, bright, dim. It manages these well from both the iPad app, as well as the hand-held remote.
With that said though, I'm a little disappointed with how you have to operate the lights. I need to figure out a better way run the activities. For example, I set a watch movie activity with TV, amp, blu-ray, and the lutron. In order to dim it goes full bright than it works to the added commands. Then when I switch to watch tv it goes off then follows the commands of the watch tv activity.
It would be nice to be able to add the commands for a component without having to first do the power on step. If you don't list the item as a power on item to begin with, you don't have the ability to add commands within that activity.
Originally Posted by tboe77 View Post
+1
I have Lutron IR dimmers and I have my remote set up so it does not turn the lights on or off when starting or ending an activity, which is what I think you want to do.
How I did it: For my Lutron light device, go to the device settings, then change device settings, then power settings. At the next screen I selected "I want to leave this device powered on all the time", then the next screen I selected "I press two different buttons for on and for off". At the next screen for the power on commands and power off commands, I selected/created a "bogus" command that doesn't do anything with the lights. This was to make sure that if the harmony sent a command when I started or stopped an activity, it still wouldn't control the lights.
Hopefully that process makes sense. I now control my lights with the press of a soft button on the screen. I have "all lights on", "lights preset", and "all lights off" on the screen for each of my activities.
tboe77 likes this.
eecyclone is offline
post #1726 of 3762 Old 03-06-2014, 07:19 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
Yes.
Is it "Normal" ?....I would have to say yes based on the following:
While viewing your "Home" screen on the Ultimate, you see a list of your Activities. If you slightly scroll that list UP towards the top of the "Home, battery level, Time display" you will see that the first Activity overlaps those icons. When this occurs the impeding Activity will be non responsive to the touch.
CaptMike is offline
post #1727 of 3762 Old 03-06-2014, 09:55 AM
jflatt's Avatar
Hello everyone,
Regards to all,
Sylvain
Can you guys get it to update the firmware automatically? The appeal of the Ultimate Hub is the RF where it can be hidden away. It's a pain to take everything out and plug it into a computer to upgrade the firmware
jflatt is offline
post #1728 of 3762 Old 03-06-2014, 10:22 AM
Quoted: 37 Post(s)
Liked: 49
Originally Posted by CaptMike View Post
Yes.
Its it "Normal" ?....I would have to say yes based on the following:
Thanks Capt. That's what I was thinking. It seem that the screen works as it should when in swipe mode. I just haven't used it enough to find its little quirks.
post #1729 of 3762 Old 03-06-2014, 10:25 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
The hub does not transmit RF...the RF is between the remote and the hub only.
You do not have to "take everything out and plug it into a computer to upgrade the firmware"
You upgrade the firmware when you "Sync" your remote.
You plug your remote into your computer and sync via myharmony.com
CaptMike is offline
post #1730 of 3762 Old 03-06-2014, 12:10 PM
Quoted: 106 Post(s)
Liked: 52
Hi jflatt,
If your hub is connected to Wi-Fi, you'll be notified (on the remote's screen) to connect your remote to the computer, and the hub is then updated through Wi-Fi. This isn't automatic per se, but still avoids having to remove the hub from your cabinet for an update.
Sylvain
post #1731 of 3762 Old 03-06-2014, 12:14 PM
jflatt's Avatar
I could swear this failed before. I think the remote wanted to communicate with the hub, and couldn't because the computer and the hub were on opposite sides of the house.
jflatt is offline
post #1732 of 3762 Old 03-06-2014, 12:35 PM
Quoted: 106 Post(s)
Liked: 52
Another option would be to change your Lutron IR Dimmer's power settings to 'There are no power buttons on my Lutron...'. This will allow you to include it within each of your Activities without having any power commands sent to it. You can then assign power or dimming commands to your LCD or hardbuttons.
Sylvain
Edit - the only downside here is that you'd have to power off your lights before you power off your Activity, or do so from device mode once your Activity is stopped.
post #1733 of 3762 Old 03-08-2014, 04:21 PM
KdxGuy's Avatar
I am using an old 650 remote right now and it works fine for my system. I was considering upgrading to the ultimate for lighting control. Is it possible to have the pause button send the regular pause command for whatever activity is running and have it also bring the lights up then back down when the play button is pressed? It is used in a dedicated theater and would be nice to have light when we pause for a bathroom break or something.
KdxGuy is offline
post #1734 of 3762 Old 03-08-2014, 07:53 PM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
Yes
By default the pause button is programed to pause the device for either a long press or short press.
Assuming the lights were dimmed as part of your Activity, I would then reprogram the pause button for short press pause and lights on for long press.
CaptMike is offline
post #1735 of 3762 Old 03-08-2014, 08:23 PM
Redfin's Avatar
Sylvain
That's why I've always loved this forum. Thanks so much, I never thought to click into this setting as the lights operated on/off, bright/dim just fine.
I know this is silly, but I love being able to touch the "watch a movie" button and having the lights go to the preset dim position. Thanks for the help making this work.
Redfin is offline
post #1736 of 3762 Old 03-08-2014, 08:34 PM
KdxGuy's Avatar
I suppose that would work. At least I would have one button control to pause and turn on lights. Would it be safe to assume that I could do the same with the play button to restart play and dim lights?
KdxGuy is offline
post #1737 of 3762 Old 03-08-2014, 08:51 PM
Redfin's Avatar
Yeah, it does. For the play/pause buttons, it looks like you'd have to add the lighting to the play/pause buttons as a sequence. I personally am not going to do this because -- at least in my case -- I'm worried about having a lighting baseline. If you sequence the play button to dim, then every time you hit play it will dim. So if you rewind then hit play, it will dim, FF, etc. The lights may be off in no time.
I set mine to the top level watch a movie command, so that when pressed the lights go completely off -- to set the baseline, then up three button presses of bright.
Redfin is offline
post #1738 of 3762 Old 03-09-2014, 08:51 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
No need to add as a sequence. If added as a sequence that will produce the adverse effects you have noted. Instead, he just needs to program the play hard button LONG PRESS to dim the lights
CaptMike is offline
post #1739 of 3762 Old 03-09-2014, 11:06 AM
KdxGuy's Avatar
I see some refurbished ultimates around for$210-220. I think I might give it a try.
KdxGuy is offline
post #1740 of 3762 Old 03-09-2014, 11:51 AM
rstand's Avatar
Quoted: 24 Post(s)
Liked: 24
People have had pretty good luck with refurbs as long as they come from an outfit with a proven track record. A few weeks back BB had a sale on the Ultimate for $249 which is as good as I have seen for a new one.
rstand is offline
Reply Remote Control Area
Logitech 915 000201 Harmony Ultimate Remote , Logitech 915 000194 Harmony Smart Control
